dash charger availibility
  1. shreeni.oneplus Cupcake Jul 10, 2019
    shreeni.oneplus, Jul 10, 2019 :
    the dash charger was out of stock for weeks and now the product is removed. with OnePlus 7 using dash charger. it doesn't warrant such situation....
    I had a query with the customer support they confirmed that dash charger will be back in stock and advised not to use the warp charger for my OnePlus 3t.
    any update or support will help. thank you
  2. Paschfire KitKat Jul 10, 2019
    Paschfire, Jul 10, 2019 :
    Look on Amazon. There's dozens of USBC cable options available that support Dash charging on the 3/3T.
    There are even OEM OnePlus cables available, read the reviews/comments to find authentic versions.
  3. F_Mohammed_Shahin_QTDm Cupcake Jul 13, 2019
  4. shreeni.oneplus Cupcake Jul 16, 2019
    shreeni.oneplus, Jul 16, 2019 :
    I need the adaptor.. not the cable
  5. Paschfire KitKat Jul 16, 2019
    Paschfire, Jul 16, 2019 :
    From looking at your profile information I assume you're a new user of the OnePlus forums. If yes, then it's not for no reason.
    In this case, if you READ the terms/rules that are displayed before posting a new thread you'd know why.
    It's right after the * at the very bottom of the new thread message creation page.
