R1577161655899 , via OnePlus 7 , Nov 29, 2020 : My dash charger doing normal charging not doing rapid charging what is the problem
J4t1np4r3kh , via OnePlus 7 Pro , Nov 29, 2020 : Many threads like this have been created with varying advice. If everyone posted under one thread all the advice would be in one place. But from the top of my head what I've read is the following said: 1) Check there is no damage to the wire or the plug socket itself 2) Use a cotton bud or some small item to clean out the charging port and possibly the charger itself 3) Try switch on the charger, then plug the charger into your phone. 4) Can't remember any others so just search dash charge and you'll find other things to try 🤷♂️
Iamhasannaqvi , via OnePlus 7 , Dec 3, 2020 : Usually it's due to the defects in cable. Try replacing the old with the new one.
irfanmoosani , via OnePlus 7 , Dec 6, 2020 : Check if there is layer of dust on usb c port on the end of cable. If there is, try to clean it.
irfanmoosani , via OnePlus 7 , Dec 11, 2020 : The issue got resolved by cleaning the layer of dust on usb c port at the end of cable.
irfanmoosani , via OnePlus 7 , Dec 11, 2020 : You don't need to be pessimistic. The issue got resolved for someone here.
garvbatra_7 , via OnePlus 7 Mirror Blue , Dec 11, 2020 : Check the wire may be some issue or adapter if not then contact the store will be better or the service center near you
Nikz_9 , via OnePlus 7 , Dec 11, 2020 : Check the temperature of your device. I'm my case if the phone is too warm, it will charge at normal charging speed, so that might be an issue
anupz , via OnePlus 7 , Dec 11, 2020 : Sometimes if the phone is not at room temperature, then in rare case it happens.
