DASH CHARGER ON ONE PLUS 7 PROP
  1. Neiloo692494 Cupcake Jun 18, 2019
    Neiloo692494, Jun 18, 2019 :
    I had a one plus 3 with the dash charger! now I've got the one plus 7 pro....can I use the dash charger on the one plus 7 pro??
  2. L1560405899967 Cupcake Jun 19, 2019
    L1560405899967, Jun 19, 2019 :
    I'm have been using the Dash-charger that came with my OnePlus 5. The 7 Pro tells me it's "charging fast", about 3300mA according to Ampere, not Warp-charge of course. I'd guess the OP3 charger should work fine for you.
  3. Menahjatwa Eclair Jun 19, 2019
    Menahjatwa, Jun 19, 2019 :
    what gm19xx is your set?
    I am using the gm1910 and Dash Charge doesn't work on my unit. My current charges around 12xx-14xx mA like in the pic below.
  4. L1560405899967 Cupcake Jun 19, 2019
    My phone is a GM-1913
    Here is a screenshot, do you use the original USB-cable that came with your OnePlus?
