Dash Charger
  1. kmohit14
    Froyo Apr 12, 2017
    kmohit14 , Apr 12, 2017 :
    My OP2 used to fully get charged in 4 hrs....Was fed up of slow charging
    Then bought Dash Charger and boom....Super fast charging compared to previous timing....Now gets charged in approx 2 hrs
    And its also giving improved backup time...
    Another good thing is that i havent received 3.5.8 update(which is shit..drains lots of battery)
  2. ExtremeNuker
    Gingerbread Apr 12, 2017
    ExtremeNuker , Apr 12, 2017 :
    Can be the case, that you charge with 2A and your old Charger was faulty?
    floomue and shayanzahedana like this.
  3. G_SANTOSH_VERMA_FZkN
    Froyo Apr 12, 2017
  4. ganeshknr
    Ice Cream Sandwich Apr 12, 2017
    ganeshknr , Apr 12, 2017 :
    It doesn't what ampere or voltage the charger outputs as the phone is designed to take 5V/2A. Either there was a fault in the charger or you are falsely promoting.
  5. Pedro RCPinto
    Cupcake Apr 12, 2017
    kmohit14 likes this.
  6. kmohit14
    Froyo Apr 12, 2017
    why would i falsely promote...?
  7. ganeshknr
    You could provide some proof :rolleyes:
  8. mukthar.mohammed
    mukthar.mohammed , Apr 12, 2017 :
    get a VPN app select your server as Canada or anyother country where 3.5.8 is released and go refresh your software update place. worked for me
  9. G_Basanta_Rijal_OcWi
    Donut Apr 12, 2017
    G_Basanta_Rijal_OcWi , Apr 12, 2017 :
    Were you not using the original charger initially? Because I use one and my phone takes hardly 2 hours to charge completely. The Dash Charger shouldn't have any special effect than the OP2 charger as fast charging is not supported by OP2.
  10. G_preetham_Masetty_YZfk
    Eclair Apr 13, 2017
