Dash Charger
  1. Attuul_Geriyan
    Cupcake May 1, 2017
    Attuul_Geriyan , May 1, 2017 :
    I would like to know whether the one plus 3T charger works properly.
    I recently purchased a one plus 3T phone and I have some questions:
    1. Does the phone charge in 30 mins??
    2. When I started to charge the phone it was 24% later after 46 mins it was 91%. Is this normal??
    3. Does the dash charge happen only when the battery is 0% and after it gets charged up to 50-60% does the charging get slow????
    syed9640 likes this.
  2. F_Diganta_Koner_WIXu
    Jelly Bean May 1, 2017
    F_Diganta_Koner_WIXu , May 1, 2017 :
    Yes it's absolutely normal. Dash charger charges your phone from 0 to 60 in 30 mins then on it chargea normally because beyond that pushing too much current can cause damage to the battery.
  3. F_Sérgio_Vasconcelos_dN
    Cupcake May 1, 2017
    F_Sérgio_Vasconcelos_dN , May 1, 2017 :
    Hi! yes i read a lot about it, the phone takes 1hour to be fully charged. In the first 30min the phone charges to 60% and then the charge slows down till it reaches 100%
  4. immadeofpixels
    Eclair May 1, 2017
    immadeofpixels , May 1, 2017 :
    As a general rule, batteries must charge slower as they approach maximum capacity so that they can avoid overcharging. The faster it can charge when it's low, the sooner it will have to start slowing down.
    Akawe94 likes this.
  5. syed9640
    Eclair May 1, 2017
  6. Fitzy07
    Cupcake May 1, 2017
    Fitzy07 , May 1, 2017 :
    It dash charges to when you're near 0 then it slows down after 60.
    60% charge will do you a long time though!
  7. Abhinav_Shukla_One
    Donut May 1, 2017
  8. McPlayHD
    Donut May 1, 2017
    McPlayHD , May 1, 2017 :
    It's the same while using it... The first 40% will hast for the same duration as the last 60%.
    Its because of the Licium-Ions that can't put up the currency anymore.
    Giannis_Xalikia likes this.
  9. meatandy
    Oreo May 1, 2017
    meatandy , May 1, 2017 :
    1. No
    2. Yes
    3. Yes
    It should take roughly one hour and ten minutes to charge from 20% to 100%.
    dsmonteiro and Giannis_Xalikia like this.
  10. Brooklyn701
    Honeycomb May 1, 2017
    Brooklyn701 , May 1, 2017 :
    Boy some people have real trouble reading. Mainly from India... it seems...
    The promise is a days power.... NOT a full charge. Please learn about the difference between those two!
  11. Giannis_Xalikia
    Gingerbread May 1, 2017
    Giannis_Xalikia , May 1, 2017 :
    exactly but should we charge between 20-100 or 0-100 let it all drain or not
    meatandy likes this.
  12. G_Gigi_Abzhdandadze_Owxi
    Donut May 1, 2017
    G_Gigi_Abzhdandadze_Owxi , May 1, 2017 :
    Dashcharging is pmuah
  13. meatandy
    Oreo May 1, 2017
    Something around 10-15% to full is usually a good practice.
  14. G_Gigi_Abzhdandadze_Owxi
    Donut May 1, 2017
    teedeeus and Giannis_Xalikia like this.
  15. Jstarr96
    Donut May 1, 2017
    Jibin_Mathew and Sreehari.k.t like this.
  16. Giannis_Xalikia
    Gingerbread May 2, 2017
  17. Giannis_Xalikia
  18. Mohamed Fyzil
    Cupcake May 2, 2017
    Mohamed Fyzil , May 2, 2017 :
    Try to put the phone on flight mode and charge, if you want to charge the battery faster..
    YabbaShabba likes this.
  19. G_Chetan_Danu_whAq
    Cupcake May 2, 2017
  20. dev646
    Donut May 3, 2017
