Dash charging not working nd cant connect to pc
  1. 4867
    Cupcake Sep 11, 2017
    4867 , Sep 11, 2017 :
    hi guys.
    having this issue , when charger is connected its only showing normal charging not dash charging. charger is fine , checked with other device. there is some issue with my device.
    second , while connctng to pc , nothing is happening except charging.
  2. Shreysethi
    Eclair Sep 11, 2017
    Shreysethi , Sep 11, 2017 :
    When you connect to pc.
    You have to change from only charging to file transfer
    See for the Android sign when you connect to pc in your pull down menu
  3. G_Gyan_Droid_TUme
    Honeycomb Sep 11, 2017
    G_Gyan_Droid_TUme , Sep 11, 2017 :
    contact onplus support if dash charge is not working with dash charger
    when you connect mobile to pc change usb configuration to mtp for file transfer
    4867 likes this.
  4. Mukund760
    Mukund760 , Sep 11, 2017 :
    well the dash charger sometimes takes some time to switch to dash charging mode leave your device plugged in for a little bit(max 5 mins) it will eventually switch to dash charging mode. That's how my device works(sometimes)
  5. Mukund760
    and to connect your device to pc you need to make sure that your device is on file transfer mode and not on charging mode
  6. gstavrev
    Froyo Sep 11, 2017
    gstavrev , Sep 11, 2017 :
    Had the same problem a few months back. Had to send the phone to Oneplus for repair. Turned out to be a problem with the MB so they changed it under warranty. It took 5 days in total, including shipping time.
    Thumbs up for OP customer support :)
    4867 likes this.
  7. leo98918
    Ice Cream Sandwich Sep 11, 2017
  8. 4867
    yes i knw this. dint work.
  9. 4867
    doesnt change even aftr hours
  10. 4867
    thanks mate. have to do this only
  11. bartbarendrecht
    Donut Sep 11, 2017
    bartbarendrecht , Sep 11, 2017 :
    Had the same problem with my 3T. Eventually it turned out to be a simple problem. There was quite some dust in the USB-port of the phone. Removing it with a needle did the trick for me!
    Robson_DeluXeXBR likes this.
  12. Robson_DeluXeXBR
    Eclair Jul 11, 2018
    Robson_DeluXeXBR , Jul 11, 2018 :
    Hello, I am with the same problem. I cleaned and didn't make the trick. I think it is the type c flex cable. I will buy a replacement part because my warranty time finishes. Someone here already changed the flex cable type c ?
  13. G_bhavik_purohit_WNiM
    Cupcake May 21, 2020
    G_bhavik_purohit_WNiM , May 21, 2020 :
    i had same problem..... with my oneplus 3..
    i search lots on Internet about it....but everyone give suggestions like open setting and do this and that.... but non of them solve it... so finally i open my phone... you can search in you tube "how to repair charging plug in one plus 3"....you just have to change charging belt in that.... because due to water or other things our charging plug is lit bit damaged in mobile.... So manually i open that and buy it from local mobile repairing shop... it costs me 250 rupees .... after that now my dash charging work completely and also i can connect my oneplus 3 to my laptop... hope it helpful for you
    N1578319740413 likes this.
