dash charging not working properly via OnePlus Community App
  1. P1576041872266 , via OnePlus Community App , Apr 14, 2021 :
    few days ago i updated to 10.3.9 and after that my dash charging is not working properly ,takes more than double time to charge and now 2 days it doesnt charge even to 100 percent though it showing 100 but the battery calibration is going wrong plz fixed this
    rHITkM. likes this.
  2. Tokolozi
    Most Original Avatar Apr 14, 2021
    Tokolozi , Apr 14, 2021 :
    Do you have optimized charging enabled?
    Also check for dirt in any of the connectors.
  3. #3
  4. #4
  5. rHITkM.
    Honeycomb Apr 20, 2021
    rHITkM. , via OnePlus 6 , Apr 20, 2021 :
    Did you update via OTA or full zip?
  6. rHITkM.
    It might be taking 1.35 hours to charge to full 100% ?
  7. sumitMZ007
    Jelly Bean Apr 20, 2021
    sumitMZ007 , via OnePlus 6 , Apr 20, 2021 :
    Earlier when I was on OTA 10.3.4 my charging speed was 3% per minute and now I'm on 10.3.5 and charging speed is reduced to 2% per minute! It might happen that charging port has accumulated dust that's why it's taking time for charging as inner pins aren't aligned properly due to dust! Clean the port using some toothpick and see if charging speed get's back to normal dash charge level!
  8. rHITkM.
    So you are saying 3% per minute means 100% in 33 minutes on OnePlus 6! How's this even possible . The time dash charging takes from 0 tp 100 % takes 1 hour to 1 .10 hours .
  9. sumitMZ007
    It was on OTA 10.3.4 ! It use to charge at 3% per minute speed! And aftter 80% it use to slow down and phone use to heat a little but now I'm on 10.3.5 and speed isn't that fast like 10.3.4 and phones doesn't heat also and takes around 1.15hrs to Fully charge .but I was getting 88% charge under 40 minutes when I was on 10.3.4 but now it's not like that!
  10. rHITkM.
    Same problem I am Facing after I flashed 10.3.9 full zip after a factory reset . And now charging time in 1.40 hours . It happened just after the update. This can't be a hardware related I guess. My take here is that OnePlus must have had charging algorithm programming into the OS which is now not recognised by the device.
    sumitMZ007 likes this.
  11. sumitMZ007
    I agree! 10.3.9 has even put some devices into unusable state and that's why I haven't updated since 10.3.5 after seeing many facing bricking and data loss problem! Hope it gets resolved in coming updates!
    rHITkM. likes this.
  12. #12
  13. P1576041872266 , via OnePlus Community App , Apr 21, 2021 :
    may its issue get via google play system update what do you think
  14. P1576041872266 , via OnePlus Community App , Apr 21, 2021 :
    via OTA and after 5-6 days slowly its started happening maybe its causing via google play system update because on 4 th day i updated that also and now i just did factory reset and backup everythong still its happening....
  15. B1618877476042
    Cupcake Apr 22, 2021
  16. Abhijith_Cherian
    Froyo Apr 23, 2021
