DASH CHARGING NOT WORKING
  1. N1545661440683
    Donut Dec 26, 2018
    N1545661440683 , Dec 26, 2018 :
    yes my led notification turn blue and automatically it turns off in 3seconds.. is there any solution?
  2. N1545661440683
    Donut Dec 26, 2018
    while charging my one plus 5 with dash charger first notification led turn yellow then after few second it turns into blue color and at last it turns off.. but charging sign shows in the display but charge does not increase...help please any solution?
  3. powerofred
    Jelly Bean Dec 26, 2018
    powerofred , Dec 26, 2018 :
    Really can't say anything till I take a closer look at your device.
    Things you can try.
    1. Flip the cable and try charging.
    2. Try holding the cable near the port's end and bend at an angle where the LED stays blue.
    3. Try changing the cable/adapter.
    If none works,
    4. Get it to a service centre.
    N1545661440683 likes this.
  4. N1545661440683
    Donut Dec 30, 2018
    N1545661440683 , Dec 30, 2018 :
    vinothneo
    Here it is. As you said it shows fast charger as yes. But why it is not shown as dash charging in notification. Is it a problem?
    it shows exactly same as your but automatically charging disconnected.
  5. NightmarishPT
    Froyo Jan 3, 2019
    NightmarishPT , Jan 3, 2019 :
    I have the same problem since last month.
    Everything is white but the dash charge says no..
  6. Amar_Mahmoud
    Cupcake Feb 3, 2019
  7. Aditya666
    Cupcake Feb 12, 2019
    Aditya666 , Feb 12, 2019 :
    I also faced with same problem.
    I fixed it by cleaning the charging port.
    And surprisingly I found lot of dust in it.
    Just take one needle and clean it smoothly.
    And wohoo dash is again working.
  8. W1540122896104
    Cupcake Apr 15, 2019
    W1540122896104 , Apr 15, 2019 :
    Simple solution Take a toothbrush and scrub on Type C Port (internal) after Scrub wait for dry or Blow some Hot Air with Hair Dryer on Type C port (1min) after that Conect ur Charger. Voilaaa Dash is working Now. Must Tty.
  9. Akhshay Srinivasan
    Nougat Apr 19, 2019
    Akhshay Srinivasan , Apr 19, 2019 :
    Check if :
    > The sockets are stable
    > The C-type cable is undamaged
    > The adaptor is in good condition
    If the above are satisfied and still the issue persists, contact OnePlus service centre placed nearby.
  10. P1574153163879
    Cupcake Nov 19, 2019
    P1574153163879 , Nov 19, 2019 :
    I have OnePlus 6 and dash charge is not working. Attached is the screenshot.
    [QGav_W86, post: 17814810, member: 1111300"]If the LED changes it sounds like it is recognising it as DASH.
    go to engineer mode (dial *#808# in dialler app) then choose the test "Charger (Fast Charger)" - it should give you the charger voltage, the battery temp & capacity, the current, and a yes/no as to whether it is a fast charger. screenshot that and post up here.[/QUOTE]
  11. SaurabhZaware
    SaurabhZaware , Nov 19, 2019 :
    I have been having the problem where dash charging on my phone is not being enabled but it worked on other one plus phones.
    The solution that worked for me : blow air with your mouth around thrice to remove dust from the charging port
  12. J1586174680736
    Cupcake Apr 6, 2020
    J1586174680736 , Apr 6, 2020 :
    Two important things to check for dash charging work:
    -clean your phone charging port from dust (by air compressor or manually by mouth)
    -make sure red cable is well attached to the charger! (My wasn't and that was the main reason my dash charging didn't work!)
  13. pauliprokki
    Froyo Apr 12, 2020
    pauliprokki , Apr 12, 2020 :
    clean your phone charging port from dust and lint from your pocket. This help me when my dash charger wont work.
  14. B1542135461128
    Cupcake Jun 23, 2020
    B1542135461128 , Jun 23, 2020 :
    HI, so I am also using the same charger and cable but it stopped dash charging at some point half an year ago, now it's not even charging, only the orange LED is on, the charging symbol is not there is it phone hardware problem or charger problem?
  15. Paskal
    Cupcake Jun 25, 2020
    Paskal , Jun 25, 2020 :
    I'm also getting negative current reading once in a while. Should I be worried and change the dash charger? Phone battery is normal though, can last a day.
