Dash charging stopped working. Using origional cable from Oneplus store. Never used other charger. via OnePlus 5
  1. rahulranjan87
    Cupcake Oct 20, 2020
  2. Tokolozi
    Nougat Oct 20, 2020
    Tokolozi , Oct 20, 2020 :
    Did you try another dash charger and cable to see if they do work?
    Check if there is no dust buildup.
  3. egorian
    Gingerbread Oct 21, 2020
    egorian , via OnePlus 5 , Oct 21, 2020 :
    I had the same issue. Tried a new charger and new cable with no success. I had to replace the charging port on my OP5 to solve it.
  4. Oreo.
    OnePlus Accessory Tester Oct 21, 2020
    Oreo. , via OnePlus 5 , Oct 21, 2020 :
    OP5 is quite old now. Charging port has suffered enough wear and tear. I'm facing the same issue with dash charging, while the same charger is charging my OP6 with dash speed, it fails to dash charge my OP5. I have to plug in with force and keep the phone in one position to let it charge otherwise it stops charging at all
    Issue is surely with the charging port, just get it replaced.
  5. drmartin
    Lollipop Moderator Oct 21, 2020
