Dash charging to Slow charging
  1. PrateekSinghania
    Eclair Sep 25, 2020
    PrateekSinghania , Sep 25, 2020 :
    Is it just my phone or other 6t users are facing the same problem of slow charging.
    Before my phone would charge 5-80 percent in approx 55-60 mins but now in 2 hours my phone was charged for about 82 percent.
    Yes, there was the sign of my mobile charging rapidly.
    Please help me out .
  2. Dinesh 6004
    Eclair Sep 25, 2020
    PrateekSinghania likes this.
  3. PrateekSinghania
    Eclair Sep 25, 2020
    shit bro[e]1f637[/e]the new update is buggy i guess . And i am not liking it.
    I really thought my charging port or my charger is giving problems
  4. Caomhin
    Marshmallow Sep 25, 2020
    Caomhin , via OnePlus 6T , Sep 25, 2020 :
    Clean the ports on the phone, charger and both ends of the USB cable with a fine dry toothbrush or non conductive wooden or plastic toothpick carefully.
    See if that helps
    PrateekSinghania and zayn_ys like this.
  5. Enchantress
    Eclair Sep 25, 2020
    Enchantress , via OnePlus 6 , Sep 25, 2020 :
    What's the room temperature when you're charging. i have noticed with more heat dash charging takes more time.
    Try with ac on , you'll see a lot difference.
  6. 01312223111
    Cupcake Sep 25, 2020
  7. Caomhin
    Marshmallow Sep 26, 2020
    Caomhin , via OnePlus 6T , Sep 26, 2020 :
    You can use many different chargers so long as the cable is USB C, however you may not get the full Dash/Warp Charge speeds of the original OnePlus charger.
    01312223111 likes this.
  8. G_gulshan_kumar_wgJp
    Cupcake Sep 26, 2020
    G_gulshan_kumar_wgJp , Sep 26, 2020 :
    Yes i have oneplus 6 and from yesterday afternoon I am also facing same issue. I tried factory reset and different cables and powerbank but it's charging very very slow. Like in shout down state it charges 70% in 7 hours. What should I do? It could be a charger problem or software problem?
  9. Caomhin
    Have you tried the steps mentioned above to clean all the connection points, works for most.
  10. PrateekSinghania
    Eclair Sep 29, 2020
    PrateekSinghania , Sep 29, 2020 :
    hey thankyou so much it did helped!!!
    Caomhin likes this.
  11. PrateekSinghania
    Eclair Sep 29, 2020
    i didn't kept the ac on while charging
  12. Caomhin
    Marshmallow Sep 29, 2020
  13. PrateekSinghania
    Eclair Sep 29, 2020
    try to charge your mobile from the original regular charger
    it helps in long duration
    Caomhin likes this.
  14. PrateekSinghania
    Eclair Sep 29, 2020
    it is the software problem
    i got my thing fixed .
    try the cleaning process . or if it doesn't work wait for the next update :(
    Caomhin likes this.
  15. PrateekSinghania
    Eclair Sep 29, 2020
    Caomhin likes this.
  16. Raki2657
    Cupcake Sep 29, 2020
    Raki2657 , via OnePlus 6 , Sep 29, 2020 :
    Even I had a same issue.. I just took all the data and reset the mobile by using boot menu option. Now it's working also increased the battery life.
  17. PrateekSinghania
    Eclair Sep 29, 2020
    cool that bro .
    Caomhin likes this.
  18. B1529399610597
  19. riyaz7861
    Eclair Sep 29, 2020
    riyaz7861 , via OnePlus 6T , Sep 29, 2020 :
    Downgrade to Pie and check if the issue is still there?
  20. Reeyaaz
    Cupcake Oct 2, 2020
