Data Saver is not working on my OP5
  1. Nil_s7
    Gingerbread Oct 25, 2018
    Nil_s7 , Oct 25, 2018 :
    I have enables datasaver option from quick settings but still applications are able to connect mobile data in background and showing notifications . This function is working perfectly on my moto G5s plus. Please confim anyone facing same issue on OP5.
  2. G_David_Sidrak_rYck
    Honeycomb Oct 25, 2018
  3. Paschfire
    KitKat Oct 25, 2018
    Paschfire , Oct 25, 2018 :
    Did you make sure whatever app is still using data has the data saver applied to it?
  4. Waveform Modifier
    Marshmallow Oct 25, 2018
    Waveform Modifier , Oct 25, 2018 :
    Data saver is not no data. If you want no data, do what @G_David_Sidrak said.
    G_David_Sidrak_rYck likes this.
  5. G_David_Sidrak_rYck
    G_David_Sidrak_rYck , Oct 25, 2018 :
    feel nice to get appreciated every once in a while.
    Waveform Modifier likes this.
  6. Waveform Modifier
    I appreciate sound logic.
  7. Nil_s7
    Data saver means no application in background consume mobile data.
  8. Waveform Modifier
    It will limits it. IF you have some permission set to ignore it, it will still goes through.
  9. Nil_s7
    I have unchecked all applications from the provided list but still whatsapp is able to work in background and fetch messages from server . If you have motorola handset please check this feature.
  10. Waveform Modifier
    What Motorola handset? This is a OnePlus user forum. Not Motorola.
  11. G_David_Sidrak_rYck
  12. Waveform Modifier
  13. Nil_s7
    Hahaha check on any other android phone.
  14. Waveform Modifier
    Why should I? We are talking about OnePlus phones here. Not other phones. If you want to talk about other phones, go to the off topics section.
  15. F_Terence_Quah_gSCv
    Ice Cream Sandwich Oct 26, 2018
    F_Terence_Quah_gSCv , Oct 26, 2018 :
    data saver does not means no data. it only slowed down the refresh rate of ping to get msg(example). instead of few secs..become a minute once etc.
    if u want it to behave like other phones like u claimed, u have to manually set all the permission 1by1 of every single app u have(custom set all you want yourself) to low priority for example. I'm wondering, are you sure it's "data saver and not battery saver", each different phone battery saver have different level of saving, some goes limit till almost airplane mode, while some just tone down everything to low usage while maintaining normal use even for internet/data.
