data speed on title bar
  1. Jaspreet88 Eclair Jun 16, 2019
    Jaspreet88, Jun 16, 2019 :
    I have noticed one thing while using Wi-Fi network , the title bar is not showing transfer speed on it as i switch my network to mobile data, it starts displaying the network speed without doing any change in the settings.
  2. A1560831483060 Cupcake Jun 18, 2019
    A1560831483060, Jun 18, 2019 :
    this is because the transfer speed is displaying under the notch area. if you remove any extra icon on the notification bar like VOLTE, you'll be able to see the network speed
    vgupta1192 likes this.
  3. vgupta1192 Gingerbread Jun 18, 2019
    vgupta1192, Jun 18, 2019 :
    yeap
    A1560831483060 likes this.
  4. A1560831483060 Cupcake Jun 18, 2019
  5. niket17590 Donut Jun 20, 2019
    niket17590, Jun 20, 2019 :
    they are only utilizing right side of notch to display icons and limit is max 5. they should utilize left side of notch as well to display more
    vgupta1192 and A1560831483060 like this.
  6. Neddard Lollipop Jun 20, 2019
    Neddard, Jun 20, 2019 :
    Is it really that important to see network speed?
  7. niket17590 Donut Jun 20, 2019
    yes it becomes important when you live in country a where network speed varies from 4g to 2g if you roam around different areas
  8. Neddard Lollipop Jun 20, 2019
    What does seeing a speed indicator do for you? Wouldn't the 4G or 2G indicator suffice?
