Dear sir /mam plz help me for mistake what i have done
  1. L1592642101532
    Cupcake Sep 20, 2020
    L1592642101532 , Sep 20, 2020 :
    sorry for saying that i have root my mobile and again unrooted I need some help my mobile is is 5.5.1 and I checked to update my os but it was saying that it is already upto date now what to do I can't understand please help me to came back with latest os please sir /mam forgive me for mistake what I have done and I will never repeat it again
  2. yashwant24
    OnePlus Accessory Tester Sep 20, 2020
    Bobbie63 and Caomhin like this.
  3. Caomhin
    Marshmallow Sep 21, 2020
    Caomhin , via OnePlus 6T , Sep 21, 2020 :
    Follow the instructions to use the MSMDownload Tool for your model.
    [e]26a0[/e]️This will wipe the phone.[e]26a0[/e]️
    Ensure you Choose the software for Your Model of OnePlus 6 series phone.
    https://www.thecustomdroid.com/oneplus-6-6t-unbrick-guide/
    Scroll down to view the Unbrick details and downloads.
    Download and use the Android version you want TO use to unbrick the phone .
    Once you have the phone backup and running.
    Install OTA updates to get the most recent update.
    If you are not comfortable doing that, please contact OnePlus directly at the link below for more information. Or bring the phone to an approved OnePlus service center.
    Scroll down the page for contact details.
    Bobbie63 likes this.
  4. Bobbie63
    Bobbie63 , Sep 21, 2020 :
    That's a bit of a big measurement, isn't it? From what I understand he didn't brick his phone. Maybe just a manual update would do the trick. (however I would first reset the phone, just to be sure)
    Caomhin likes this.
  5. Caomhin
    Said he wanted to go back to latest OS from rooting a phone. Easiest way to do that is to use the Unbrick method, it's not just for unbricking. When you root and unroot involves u locking the Bootloader which wipes the phone, he sounds apparently stuck on latest update, which he hasn't specified what that is, so using this method is the simplest way to fix it back to normal. No idea if he tried a custom Rom or not.. And he mentions being on 5.5.1, which is not even an OOS update unless its mistyped.
  6. Bobbie63
    About the 5.5.1 found that also a but weird:p
    But in fact you're right, thanks for the info. :)
    Caomhin likes this.
  7. Caomhin
    Had to pick through the post a bit as some of the context was out of sync, so went for the simplest solution to get back to square one. There is a more elaborate way. But you know what I mean when I say keep it simple or as simple as possible [e]1f44d[/e]
  8. L1592642101532
    Cupcake Sep 21, 2020
  9. Caomhin
    When installing manually the Changelog never appears. Only for OTA updates. But you van check the relevant thread for the OOS version installed on the phone, in the Community Forum to see what the changelog would be
  10. Tobikage
    Nougat Sep 21, 2020
    Tobikage , Sep 21, 2020 :
    Go to your nearest service center and have them flash it.
    Caomhin likes this.
  11. Tobikage
    Nougat Sep 21, 2020
    Caomhin likes this.
  12. Caomhin
    Tobikage likes this.
