51
Deep Dive: 120 Hz Fluid Display – Beyond resolution and refresh rate
  1. J1583261312375
    Cupcake Apr 23, 2020
    #61
  2. Swejuggalo
    KitKat Apr 23, 2020
    Swejuggalo , via OnePlus 7 Pro , Apr 23, 2020 :
    I doubt it. I think it would be heavily ineffective and consume a lot more power to this with software than with a dedicated MEMC ship. It's a noticable drain with the chip... Imaging the drain without it.
    Was it a question or a statement?
    #62
  3. ADMOrange
    Eclair Apr 24, 2020
    ADMOrange , via OnePlus 7 , Apr 24, 2020 :
    Dude the MEMC is a hardware chip.
    #63
  4. j0k3rip
    Gingerbread Apr 24, 2020
    #64
    ADMOrange likes this.
  5. Swatiranjan
    Swatiranjan , Apr 24, 2020 :
    Display of OnePlus is one of the best in the business. Camera is what it matters. I don't think there is enough difference in daily use for 90 Hz & 120 Hz display.
    A+ in display mate tells a story though.
    #65
  6. #66
  7. Jangidpra
    Cupcake Apr 24, 2020
    #67
  8. ADMOrange
    Eclair Apr 24, 2020
    Some articles and reviews said that apparently the S20 Ultra had the same problem, but was fixed with Samsung rolling out a software update for the issue. Probably OnePlus will do the same with upcoming OTA updates.
    #68
  9. F1557918124440
    F1557918124440 , via OnePlus 8 Pro , Apr 24, 2020 :
    I would still like to set my OnePlus 8 pro to 90hz give us that option pls. I think it would be a great compromise between battery and refresh. it would also make 1440p more viable.
    #69
  10. C1508158874911
    Froyo Apr 24, 2020
    #70
  11. guruprasad_dp999
    Froyo Apr 25, 2020
    guruprasad_dp999 , via OnePlus 5 , Apr 25, 2020 :
    there Nothing new inthat the back design is like 7pro always I prefer the t series so 8 pro . always they test like that nothing
    1. after installing the tempered glass the smoothness is same as 90Hz.
    always oneplus want a nothing new . 5G network now not available in India but they release phone
    #71
  12. guruprasad_dp999
    Froyo Apr 25, 2020
    is there anything new
    #72
  13. A_shish_K_ebab
    Donut Apr 25, 2020
    #73
  14. Yannis Neris
    Ice Cream Sandwich Apr 25, 2020
    #74
    F1557918124440 likes this.
  15. guruprasad_dp999
    Froyo Apr 25, 2020
    #75
  16. somu91
    Cupcake Apr 25, 2020
    #76
  17. smaberg
    Froyo Apr 27, 2020
    smaberg , Apr 27, 2020 :
    Hi there, I'm an old old developer at XDA developer, been cocking ROM's since 2003, started really serious when windows mobile came in 2005. Then made my way to Android development in Android 0.8 beta.
    Been implementing my tweaks to screen and battery life on almost every phone they're was in the beginning.
    JUST GOT MYSELF AN ONEPLUS 8 PRO ULTRA NICE MARINE BLUE! LOVING IT SO FAR, ESPECIALLY THE SCREEN, WOW ❤️
    THE NEW 10-bit color depth, 4096 levels of automatic brightness adjustment is ONE OF THE GREATEST features.
    But, yes here it comes 🤪 -the one thing lacking is an advanced option for auto brightness, so you can set the minimum brightness level yourself also the max.
    FOR ME WITH AN ILLNESS THAT AFFECTS DARK VISION, I can't read anything when it's dark in the room, EVERY, AND I MEAN EVERYTIME I HAVE TO PULL DOWN THE NOTIFICATION BAR, AND YES THAT'S TWO PILLS TO BE ABLE TO SEE THE BRIGHTNESS BAR, AND THEN CHANGE IT.
    This is EXTREMELY annoying and also takes time.
    SO PLEASE, I BEEN YOU TO TAKE INTO CONSIDERATION TO ADD -ADVANCED AUTO BRIGHTNESS LEVELS.
    /THANK YOU FOR YOUR TIME, AND ALSO THE BEST PHONE EVER MADE! ❤️❤️❤️❤️❤️❤️
    #77
  18. #78
    Jeff Steiner likes this.
  19. PankajS
    Ice Cream Sandwich Apr 28, 2020
  20. #80
