59
Deep Dive: Exploring Bullets Wireless 2's sound quality
  1. eliamarisio
    Gingerbread Dec 5, 2019
    eliamarisio , Dec 5, 2019 :
    Got it, thanks ;)
    I asked because I heard that on Oxygen OS based on Android 10 this feature is missing right now.
    Sources:
    https://forums.oneplus.com/threads/android-10-bluetooth-codec-not-working-qualcomm-aptx.1106973/
    https://forums.oneplus.com/threads/...ooth-codec-not-working-qualcomm-aptx.1107004/
    https://forums.oneplus.com/threads/...ooth-codec-not-working-qualcomm-aptx.1100330/
    #41
  2. H1558732562105
    Eclair Dec 5, 2019
    H1558732562105 , Dec 5, 2019 :
    eliamarisio
    Got it, thanks
    Sources:
    you need both you devices to support aptX[e]2122[/e] HD to get it to work, it could be a bug in decoder or your phone, not sure, if its a bug it should get fixed in future update.
    #42
  3. eliamarisio
    My OP6T with Android 9 works really good with the OP Bullets Wireless 2 and Qualcomm® aptX™ HD Audio is okay.
    I'm afraid to update to Android 10 because I read that there are issues with it.
    So, if someone with Android 10 could confirm that it is working properly, I will update
    #43
  4. H1558732562105
    Eclair Dec 5, 2019
    eliamarisio
    My OP6T with Android 9 works really good with the OP Bullets Wireless 2 and Qualcomm[e]00ae[/e] aptX[e]2122[/e] HD Audio is okay.
    So, if someone with Android 10 could confirm that it is working properly, I will update​
    i got OP7Pro and im using Android 10 beta 6, aptX[e]2122[/e] HD works fine and have worked in all versions, im sure it will work on OP6T too and if it doesnt you can go back to Android 9
    #44
    eliamarisio likes this.
  5. W1575138502667
    Cupcake Dec 5, 2019
    #45
  6. N1538317292493
    Cupcake Dec 5, 2019
    #46
  7. akshaxpatil
    Eclair Dec 5, 2019
    #47
  8. MiszterSoul
    Ice Cream Sandwich Dec 5, 2019
    MiszterSoul , Dec 5, 2019 :
    Using it since 1 week, and didnt needed to charge, the wireless feeling is so great, but without thinking about every time you will lose the earbuds.. :D
    Quality is good, the material is really good, like on OnePlus phones.
    The price a bit high, but you need to buy it once, you dont will lose it like iCraps. :)
    #48
    Binoy Mathew likes this.
  9. MiszterSoul
    #49
  10. meatandy
    Oreo Dec 5, 2019
    meatandy , Dec 5, 2019 :
    Guess you missed my point.
    #50
  11. neelw1994
    Eclair Dec 5, 2019
    neelw1994 , via OnePlus 6 , Dec 5, 2019 :
    The Bullets Wireless 2 Turn Off by just attaching them magnetically...But when kept in Case, they detach and turn on accidentally lots of times.
    is there any way to manually turn them off ???
    (like bullets wireless 1 had, by pressing the Button on neck band for 5-6 seconds)
    i tried it on my Bullets wireless 2, but they dont turn off !!
    Is my product faulty ??
    do i Get it Replaced ??
    plz help guys
    #51
  12. #52
  13. Sandipbhoir83
    Cupcake Dec 6, 2019
    Sandipbhoir83 , Dec 6, 2019 :
    l am using bullet wireless 2 from last three two months , it's excellent performing...
    awesome.
    #53
    surajgupta07 likes this.
  14. Vamsi438
    Froyo Dec 7, 2019
    Vamsi438 , via OnePlus 7 Pro , Dec 7, 2019 :
    Music = great . Bass is improved from previous wireless bullets but calls are just bad when u are traffic ur mic noise cancellation is zero and other end person suffers to listen ur voice as it is dominated by surrounding noises
    Please look into this Oneplus. Yes u ppl are working hard improving everything but earphones which has to serve basic functionality taking calls itself is a drawback.
    #54
  15. #55
  16. Binoy Mathew
    Eclair Dec 8, 2019
    Binoy Mathew , Dec 8, 2019 :
    I'm aware that it doesn't increase bass.. It is to loosen up the driver as you mentioned. I had mentioned it so that users understand that sound spectrum is wider than they think.
    #56
  17. Binoy Mathew
    Eclair Dec 8, 2019
    That's normal. It shows the battery percentage in multiples of 20.
    #57
  18. Praty_28
    Jelly Bean Dec 8, 2019
    Praty_28 , Dec 8, 2019 :
    It will automatically turn off after 5 minutes of inactivity
    #58
  19. Binoy Mathew
    Eclair Dec 8, 2019
    No, your product isn't faulty. It's the same for all the BW2 users. I would say it's a design flaw. However, if your BW2s aren't connected to any device for some time (when the buds aren't attached together) they should switch off automatically. I think it's mentioned in the manual.
    #59
    neelw1994 likes this.
  20. ledsled
    Honeycomb Dec 8, 2019
    ledsled , via OnePlus 6 , Dec 8, 2019 :
    Don't worry they fit great
    Oneplus didn't even include ear wings with them this time cause they just fir so great
    Something to note is they go real deep into the ear, which might me uncomfortable to some
    #60
    Tax_Mny likes this.
