5
Delay in hanging up calls
  1. Caomhin
    KitKat Jan 23, 2020
  2. H1514803131343
    Cupcake Jan 23, 2020
    H1514803131343 , Jan 23, 2020 :
    okay thank you
  3. samnadar
    Cupcake Jan 28, 2020
    samnadar , Jan 28, 2020 :
    SOLVED!!
    I was facing this issue since the last update of OxygenOS 9.0.10
    It was really annoying and got scared if my mobile was hacked, did lots of research and followed the instruction I googled for and finally it was solved.
    It’s just a bug and OnePlus will soon address this issue.
    Follow this steps to get rid of it.
    Step 1:
    Click the CALL button
    Step 2:
    Click on the 3 dots on top right of the screen.
    Step 3:
    Click SETTINGS from the dropdown
    Step 4:
    Turn off the NOISE CANCELLATION.
    It worked for me hope it works for you too..
    Cheers,
    Sam Nadar
    DrJMun likes this.
  4. omprakasjha
    Cupcake Jan 29, 2020
  5. TheSentinel909
    Cupcake Feb 6, 2020
    TheSentinel909 , Feb 6, 2020 :
    I have the same problem - the solution by Sam Nadar did not help, unfortunately :(
    Any other ideas?
  6. yuvi_yuvraj
    Cupcake Feb 8, 2020
  7. Caomhin
    KitKat Feb 8, 2020
    Caomhin , via OnePlus 6T , Feb 8, 2020 :
    This is OnePlus 6 series thread, try OnePlus 5 series to check your issue.
    Kytharsis likes this.
  8. ashishahs2000
    Cupcake Feb 18, 2020
    krezi1 likes this.
  9. sankar2207
    Cupcake Mar 1, 2020
  10. Kytharsis
    Nougat Mar 1, 2020
    Kytharsis , Mar 1, 2020 :
    Use the 7 Series forum.
    Caomhin likes this.
  11. J1583396605594
    Cupcake Mar 5, 2020
    J1583396605594 , Mar 5, 2020 :
    Was facing the same issue since I had updated.. worked for me after clearing phone app cache data and restart
  12. D1520107581232
    Cupcake Mar 7, 2020
