Delayed incoming call notification, heating and battery drain. via OnePlus 7 Pro
  1. oza_rahul
    Cupcake Aug 1, 2021
    oza_rahul , via OnePlus 7 Pro , Aug 1, 2021 :
    I updated latest firmware and using Oxygen OS 11.0.2.1.GM21AA. I still face issue of over heating and faster battery drain. Most annoying is, incoming call notification is displayed after 5-10 seconds after phone rings.
  2. Dresa91
    User of the Year 2016; Most Active User 2020 Aug 1, 2021
    Dresa91 , Aug 1, 2021 :
    Did you submit a bug report?
    Did you clear cache in recovery?
    Did you clear cache and data of the phone app?
    Can you please share your battery and usage stats?
    J4t1np4r3kh likes this.
  3. oza_rahul
    Cupcake Aug 1, 2021
  4. oza_rahul
    Cupcake Aug 1, 2021
  5. Dresa91
  6. oza_rahul
    Cupcake Aug 1, 2021
  7. Dresa91
    Well, you did not answer to:
  8. oza_rahul
    Cupcake Aug 1, 2021
  9. Dresa91
  10. oza_rahul
    Cupcake Aug 1, 2021
  11. Dresa91
    Then submit a bug report and contact support
  12. J4t1np4r3kh
    OnePlus Accessory Tester Aug 1, 2021
    J4t1np4r3kh , Aug 1, 2021 :
    For the time being, since you've cleared cache as per @Dresa91 instructions (system, dialer, launcher) then use the Google Dialer for the time being to resolve this issue
    Dresa91 likes this.
  13. nerdkabir
    Jelly Bean Aug 2, 2021
    nerdkabir , via OnePlus 7 Pro , Aug 2, 2021 :
    Can you set you "Phone" app settings to "don't optimise" under battery optimization option? It must be on intelligent control. Hope this helps your issue for now.
