156
[Development] Lollipop
  1. ash23
    Jelly Bean Nov 23, 2014
    ash23 , Nov 23, 2014 :
    about to try liquidsmooth 4.0, will let everybody know if its better or worse than cm in terms of stability
    MoXVII likes this.
  2. Deactivated User
    Nov 23, 2014
  3. ash23
    who is "us", and not the place to beg for invites
    keessonnema likes this.
  4. MoXVII
    Gingerbread Nov 23, 2014
    MoXVII , Nov 23, 2014 :
    Could it be you've USB debugging enable automatically in dev settings? I know I did when I dirty + clean flashed
  5. Deactivated User
    Nov 23, 2014
  6. MoXVII
    Possible fix:
    1. Assuming you've not flashed the latest SuperSu (2.23 beta I think ) go into TWRP and do that.
    Tip: if you haven't got a reboot menu head into terminal and type "reboot recovery"
  7. Deactivated User
    Nov 23, 2014
  8. Denchik994
    Froyo Nov 23, 2014
  9. B4kken
    Lollipop Nov 23, 2014
    B4kken , Nov 23, 2014 :
    Did you refresh it after updating?
  10. Deactivated User
    Nov 23, 2014
  11. Deactivated User
    Nov 23, 2014
  12. keessonnema
    KitKat Nov 23, 2014
    keessonnema , Nov 23, 2014 :
    Miscellaneous battery drain again on Bpears latest build. Is there a build without it?
  13. Deactivated User
    Nov 23, 2014
  14. ash23
    if google only fixes one thing in 5.0.1, i want it to be Miscellaneous battery drain
  15. ash23
    liquid smooth is unusable. Error messages and reboots as soon as i get to the lock screen. Came from a clean install
  16. keessonnema
    KitKat Nov 23, 2014
    I have yes. I see. The GPS Icon is always present in the statusbar. That's what's draining the battery I guess. Will turn it off and reboot now.
  17. missy.wyman
    Honeycomb Nov 23, 2014
  18. Deactivated User
    Nov 23, 2014
  19. DarkSteemex
    Ice Cream Sandwich Nov 23, 2014
    Deactivated User likes this.
  20. Deactivated User
    Nov 23, 2014
    MoXVII and DarkSteemex like this.
