Device isn't being detected by laptop when connected via type c to c cable via OnePlus 7 Pro
  1. SahilNKhan
    Eclair Feb 15, 2021
    SahilNKhan , via OnePlus 7 Pro , Feb 15, 2021 :
    Neither My OnePlus 7 pro is detecting the laptop via type c to c connection nor vice versa.
    It works if I connect it via type C to type A on my laptop.
    The Type C to C cable works perfectly fine with the samsung galaxy note 10 plus, the drivers are installed and updated but my OnePlus device just won't detect or be detected by my laptop.
    Please help me.
    [Solved][kinda] Plug your phone to your laptop and reboot the phone while connected.
    P.S Could someone explain why this happened?
  2. Tokolozi
    Most Original Avatar Feb 15, 2021
    Tokolozi , Feb 15, 2021 :
    Did you try other C-C cables as well. Seeing as the A-C works it sounds more like a particular cable compatibility issue.
    Caoimhín likes this.
  3. SahilNKhan
    Eclair Feb 15, 2021
  4. SahilNKhan
    Eclair Feb 15, 2021
  5. Tokolozi
    Does it work when you use a type A to C adapter on one side of the C-C cable? (if you have one)
    Caoimhín and SahilNKhan like this.
  6. SahilNKhan
    Eclair Feb 15, 2021
    Yes it does, but it's extremely slow
    Tokolozi likes this.
  7. Tokolozi
    Slow could just be because it's using USB2.0 at that point. But seeing as it works in an A-Type port, can you ensure that the drivers are detected by the C connection as well. (sometimes two different USB controllers need to point out the drivers yourself) Generic android drivers should work.
  8. SahilNKhan
    Eclair Feb 15, 2021
    Tried that. Unfortunately you know the result 😞
  9. Tokolozi
    No further ideas then, sorry
  10. SahilNKhan
    Eclair Feb 15, 2021
  11. SahilNKhan
    Eclair Feb 16, 2021
    SahilNKhan , via OnePlus 7 Pro , Feb 16, 2021 :
    I have to restart the device while it is connected to the laptop via type c to c for it to be detected. Can you recommend to do something with this new info?
  12. Tokolozi
    Most Original Avatar Feb 16, 2021
    Tokolozi , Feb 16, 2021 :
    Maybe check if OTG is disabled then when connecting it? OTG can make it difficult to connect to a PC>
  13. SahilNKhan
    Eclair Feb 16, 2021
  14. SahilNKhan
    Eclair Feb 16, 2021
    Do you mean that otg storage which disconnects after 10 mins of inactivity?
  15. Tokolozi
    Yes, Make sure it's disabled completely, since Type C to C cables can be used both for host as slave connections they don't always have the resistor forcing the phone in "slave" mode.
    SahilNKhan and Caoimhín like this.
  16. SahilNKhan
    Eclair Feb 16, 2021
    It's disabled but I don't know what do you mean by "completely" maybe something in developer options?
  17. Tokolozi
    Could be, I honestly cant check since I don't have a 7-series.
    SahilNKhan likes this.
  18. SahilNKhan
    Eclair Feb 16, 2021
  19. Tokolozi
    Is it even detected by ADB when connecting the C-To-C cable?
  20. Cervantes
    Moderator Moderator Feb 16, 2021
    Cervantes , Feb 16, 2021 :
    Hi
    without connecting the phone
    open and check windows device manager
    connect the phone and check if a connection line appears in windows manager usb devices
    You should not have a driver alert
