Device not listing using adb on Ubuntu 14.04.3
  1. darthrider
    Froyo Dec 22, 2015
    darthrider , Dec 22, 2015 :
    I'm trying to set up adb in Ubuntu 14.04.3 (64 bit) but its not showing up when I connect my device.
    Here is what I did
    I installed adb and fastboot using these commands
    Code:
    sudo apt-get install android-tools-adb android-tools-fastboot
    I got the adb driver files from my device and executed it
    Code:
     sh ~/Desktop/adb_config_Linux_OSX.sh
    The command got executed and adb_usb.ini file got created successfully at ~/.android/ folder.
    Now I connected my device with USB debugging ON
    When I run the adb devices command this is what I get
    Code:
    List of devices attached
    The list of devices is empty.
    When I run my lsusb command
    Code:
    Bus 001 Device 005: ID 0cf3:0036 Atheros Communications, Inc.
    Bus 001 Device 003: ID 0bda:5756 Realtek Semiconductor Corp.
    Bus 001 Device 010: ID 2a70:904d
    Bus 001 Device 002: ID 8087:8000 Intel Corp.
    Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    Bus 003 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
    Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
    The vendor is not showing up. It is left blank.
    Also I have killed and started adb server with no uselful results.
    Code:
    sudo adb kill-server
    sudo adb start-server
    I tried the same method in both MTP as well as PTP mode. Still no luck.
    Could someone help me out please because I operate only on Ubuntu and can't use Windows.
  2. xgecco
    Gingerbread Dec 22, 2015
    darthrider likes this.
  3. darthrider
    Froyo Dec 22, 2015
    Tried that too. Not working.
    Should I connect in MTP or PTP mode??
  4. xgecco
    xgecco , Dec 22, 2015 :
    mtp is right but i also cant get adb to work with linux
    its working with my other devices
    let me have a look. we may need a special rule for the device
  5. darthrider
    Froyo Dec 22, 2015
    Thank you for looking into it.
    I read a guide online how to fix it with oneplus 2 and the device got listed when I updates 51 android rules file and usb.ids file.
    But then somehow I device was showing status as offfline and phone app started force closing with random reboots in device .
    The I had to dirty flash ROM over the device to fix it.
    EDIT: ADB working fine with other devices
  6. xgecco
    i got it working
    i ran the included shell script as sudo and accepted RSA dialog on the device
    it is now listed on adb devices
    try navigating to /media/<username>/Oneplus drivers
    and run "sudo ./adb_config_Linux_OSX.sh"
    then unlock your phone and accept the key
    or copy the script somewhere but make sure you run it as sudo since it will modify a systemfile and needs root priviliges
    it should work
  7. darthrider
    Froyo Dec 22, 2015
    Thank you it worked.
    Code:
    7f904cb9    device
    xgecco likes this.
  8. darthrider
    Froyo Dec 22, 2015
    Hey thanks for the help. But now the fastboot shows the device has no permissions.
    Can you help me fix that??
    Code:
    fastboot devices
    no permissions    fastboot
  9. xgecco
    try creating
    "51-android.rules" in /etc/udev/rules.d/
    with
    Code:
    # adb protocol on oneplus x
    SUBSYSTEM=="usb", ATTR{idVendor}=="2a70", ATTR{idProduct}=="9011", MODE="0600", OWNER="<username>"
    exchange <username> with your username reboot and try if it works
    never tried fastboot with linux. dont know much about it
  10. darthrider
    Froyo Dec 22, 2015
    got fastboot working too.
    I forgot to add sudo ;)
    Added sudo and fastboot works like charm.
    Now I sucessfully rooted my phone and installed twrp using Linux.
    Thanks for helping me
