Device offline?
  1. utrecht
    Gingerbread Aug 23, 2014
    utrecht , Aug 23, 2014 :
    I'm trying to get ADB working on a Mac (OS X 10.8.5) so I can encrypt my OPO. I followed these instructions:
    http://forum.xda-developers.com/showthread.php?t=1917237
    and got ADB and fastboot installed and running on the Mac. But when I run:
    adb devices
    I get:
    List of devices attached
    12345ab6 offline
    On my OPO I have USB debugging enabled and I've also tried enabling ADB over network. I also tried Revoke USB debugging authorization (no effect). I've rebooted and unplugged the OPO several times.
    Mac users, any suggestions?
  2. APatte111
    Ice Cream Sandwich Aug 23, 2014
    APatte111 , Aug 23, 2014 :
    Unplug your device, make sure USB Debugging is checked in settings... Kill the ADB Server in Terminal ( adb kill-server) and then restart the ADB Server ( adb start-server), plug your device in and try again...
    Martin Hotmann likes this.
  3. APatte111
    If that doesn't work... Make sure you are seeing the prompt about trusting the computer (which will appear on your OnePlus One when you plug the phone in)... You will need to check the always allow this computer box and click accept or trust...
  4. utrecht
    Turns out I had an older version of ADB. o_O
    Found the latest version and it appears to work.
  5. dbanez25
    KitKat Aug 23, 2014
