Device Overheating
  1. Saishyam18 Cupcake Jul 22, 2019
    Saishyam18, Jul 22, 2019 :
    My 6t gets overheated everytime whenever any 2 apps are running simultaneously. Is there any solution for this ?
  2. Scherpenseel Jelly Bean Jul 22, 2019
    Scherpenseel, Jul 22, 2019 :
    Define "overheating". Is it shutting itself down in safe mode or is the device just warm?
    Also: What apps?
  3. Saishyam18 Cupcake Jul 22, 2019
    device is becoming warmer and warmer ,
    and apps : uber , Netflix , Instagram
  4. Liehjan KitKat Jul 22, 2019
    Liehjan, Jul 22, 2019 :
    Overheating is when device turn itself off because it's overheating... Guess that's not the case with yours, how hot does it actually get?
    Kytharsis and Scherpenseel like this.
  5. Scherpenseel Jelly Bean Jul 22, 2019
    Warm is not overheating. Mobile phones get warm when heavy apps are being used (like Netflix in combination with GPS from Uber & Instagram). They also have a safeguard installed, if the phone get's to warm: it will give you a message about it.
    Kytharsis and Saishyam18 like this.
  6. Saishyam18 Cupcake Jul 22, 2019
    very hot , it's difficult to hold it in hand or to keep it in my pocket. I guess the phone temperature maybe around 40°C
  7. Saishyam18 Cupcake Jul 22, 2019
    thanks [e]1f44d[/e]
  8. Liehjan KitKat Jul 22, 2019
    40°C isn't that bad if in heavy use... But it should definitely not heat up by itself in your pocket, there might be some app that using SoC hard even when device is locked with screen off...
    Kytharsis likes this.
  9. Scherpenseel Jelly Bean Jul 22, 2019
    You could check with doing:
    *#808#
    Go in Charger ( Normal or Fast )
    There you will see internal temperature
    Liehjan likes this.
  10. TonioLA Ice Cream Sandwich Jul 22, 2019
    TonioLA, Jul 22, 2019 :
    I do have some overheating as well.
    when the top of the phone is really hot. and if it's not because of direct sunlight. it means something is wrong in it.
    can be a bad codded app or any soft issue build in the os...
    but guess what since 6t arrived OnePlus 6 has been left behind so don't expect too much in term of improvement
  11. Horsault Marshmallow Moderator Jul 22, 2019
    Horsault, Jul 22, 2019 :
    Any electronic device produces heat when working.
    This heat must be evacuated. According to environnement, this dissipation may be harder (hot temperature outside, warm object/body close by, case...) and phone will get hotter than usual. Your device may also get hotter according to network reception.
    If you combine bad network reception, phone working in background, and device in a case close to your body in summer, no surprise it's getting hot!!!
    Any further guess about company policy is just useless bad guessing in this case.
