7
Device temperature too low
  1. Asri Ameen
    Cupcake Nov 16, 2017
    Asri Ameen , Nov 16, 2017 :
    Hi guys,
    When i try to charge my oneplus 3T. it's showing an error message saying "Device Temperature Is Too Low, Cannot Charge" and the battery percentage remains at 50% until the battery drains.
    Could you please suggest a solution for this issue?? Is it a software or hardware problem??
    Awaiting for a solution for this.
    Thank you in advance.
  2. SinisterShadow
    Ice Cream Sandwich Nov 17, 2017
    SinisterShadow , Nov 17, 2017 :
    Have you tried wiping cache from recovery or a factory reset? If that doesn't fix it, maybe it's a hardware issue and you should contact the customer center
  3. Afzal Khan
    KitKat Nov 17, 2017
    Afzal Khan , Nov 17, 2017 :
    Switch it off and put it to charge for 2-3 hours straight..don't disconnect it. It will get back to normal. You can also do a clean up of cache via recovery.
    Shubham Sarwade and Qazi.Rza like this.
  4. alexheshmaty
    Cupcake Jan 10, 2018
  5. nickpetris
    Honeycomb Jan 11, 2018
  6. Dave_Freeman
    Cupcake Jan 11, 2018
    Dave_Freeman , Jan 11, 2018 :
    Hi,
    So I had this issue with my OP3 after replacing the battery. After a bit of investigation I've discovered that the temperature sensor is located in the battery (top edge). The phone communicates to it over a protocol called i2c, the middle two connections on the battery are SDA and SCL.
    So, in my instance the cheapo Chinese battery has a defective sensor, when I replaced it with one I purchased from the UK for ~£16 all is OK. I didn't need to wipe the cache or reset the phone.
    I saw exact the same symptoms that you are describing with the error message and the battery percentage stuck at 50% even when I left the Chinese battery on charge overnight.
    Bear in mind that the phone will not attempt to charge the battery if it suspects low temperature... extract from tech pub on lithium batteries (no charging is permitted at freezing temperatures because of the reduced diffusion rates on the anode).
    HTH,
    Dave (Electronics Engineer).
  7. Ravigop
    Cupcake Jan 27, 2018
    Ravigop , Jan 27, 2018 :
    Hello Dave,
    I have the same issue with my oneplus 3T, can you tell me where you bought the battery from ? I bought it from replacebase in the UK but still it didn't work.
    Thanks
    Ravi.
  8. joshprice04888
    Cupcake Feb 11, 2018
    joshprice04888 , Feb 11, 2018 :
    I have the same problem with my oneplus 3t, but when I wiped my cache it did not affect the issue. Is there any way I can fix the problem?
  9. X1518423529715
    Donut Feb 18, 2018
    X1518423529715 , Feb 18, 2018 :
    Did you find any solution as I am facing the same problem
  10. X1518423529715
    Donut Feb 18, 2018
  11. X1518423529715
    Donut Feb 18, 2018
    Did you find any solution to this as I am facing same problem
  12. Jayakanth Duraikannan
    Cupcake Jul 6, 2018
    Jayakanth Duraikannan , Jul 6, 2018 :
    Im as well facing the same issue, have tried to reset the phone (one plus 3) and still its stuck at 50% charging and showing the message "device is at low temperature".
    With the charger plugged in the phone does turn on and in Debugging mode, it does show the tempature at -40 degree where in i stay in a tropical place (@30 Degree) and still shows -40. So please do let me know if there is any solution for this.
  13. Jayakanth Duraikannan
    Cupcake Jul 8, 2018
    Jayakanth Duraikannan , Jul 8, 2018 :
    Went to service center they suggested to get the motherboard replaced... Yet to replace it... Managing with Power bank now
  14. Jayakanth Duraikannan
    Cupcake Jul 8, 2018
    Does any one else have the same issue??? Please suggest if it was resolved
  15. Harsh.Mehta295
    Cupcake Aug 16, 2018
    Harsh.Mehta295 , Aug 16, 2018 :
    I am recently facing the same issue, phone gets off due to low battery amd when i try to charge it wont.. pops an error, Device Temperature too Low.
    And after some time it switches on and battery is stuck at 50%.
    please help me..!
  16. V1521316906322
    Cupcake Nov 14, 2018
    V1521316906322 , Nov 14, 2018 :
    Hi Dave!
    Hope you're fine
    Thanks for engineering information.
    I also faced this issue and i have replaced the battery with another op3 but facing same problem. If this motherboard issue or battery because the battery which i have replaced also not used for llong time.
  17. Philippek83
    Cupcake Nov 15, 2018
    Sanpat1 and Z1541767377466 like this.
  18. A1547521320545
    Cupcake Jan 15, 2019
    A1547521320545 , Jan 15, 2019 :
    did this solution works?
  19. Afzal Khan
    KitKat Jan 15, 2019
  20. WindmillWarrior420
    Cupcake Jan 25, 2019
    WindmillWarrior420 , Jan 25, 2019 :
    I just had the same issue on my Oneplus 3 after replacing the entire frame, thought i broke the battery temp sensor or something, because it still worked with the power it had.
    Turned out i misseated the battery connector, it works perfeclty fine now.
