Device Uncertified - Oneplus 6
  1. timmaaaaaaah
    Cupcake May 27, 2018
    timmaaaaaaah , May 27, 2018 :
    According to the google play store my brand new oneplus 6 is uncertified. Anyone else have this issue?
  2. hahaha2223
    Jelly Bean May 27, 2018
    hahaha2223 , May 27, 2018 :
    is it an issue? i think it may be because op doesnt preload all the junk from google
  3. timmaaaaaaah
    Issue as some apps like Netflix not available on playstore. I know I can sideload but wonder if I will have other issues down the road.
  4. the_o2
    OnePlus 9 Series Expert Community Expert May 27, 2018
    the_o2 , May 27, 2018 :
    You unlocked the bootloader??
  5. Nezumi_
    KitKat May 27, 2018
    Nezumi_ , May 27, 2018 :
    clear google play store cache & data.
  6. Paschfire
    KitKat May 27, 2018
    Paschfire , May 27, 2018 :
    Clear Google Play Store from recents menu, clear all app data for GPS, reboot the device.
    After reboot Certified should now show within GPS app settings menu.
  7. timmaaaaaaah
    Yes. I have done this with other one plus devices with no issue.
  8. timmaaaaaaah
    Tried this. I even factory reset the device.
    Still shows uncerified.
  9. the_o2
    Unlocked bootloader have problems with play store,
    btw is your play store and Google play services is updated?
  10. the_o2
  11. Nezumi_
    KitKat May 27, 2018
    did you install magisk??
  12. timmaaaaaaah
    I just installed magisk. Then wipe everything as suggested with magisk installed and now I am certified.
  13. Nezumi_
    KitKat May 27, 2018
    yea magisk will retain device certification after you've unlocked the bootloader.
  14. Paschfire
    KitKat May 27, 2018
    Ah, I wasn't aware you had unlocked the bootloader, glad to see you got it sorted out
    Flashing Magisk plus step clearing GPS data would have been my first suggestion had I known.
    Best regards.
  15. EDIflyer
    Gingerbread May 27, 2018
    EDIflyer , May 27, 2018 :
    Probably worth mentioning in the original post tho as casts a different light on things ;) Glad you got it sorted.
  16. 404.php
    Honeycomb May 27, 2018
    404.php , May 27, 2018 :
    RMA it. Contact OnePlus support.
