Dialer blank - initially
  1. Gralith
    Froyo Sep 26, 2014
    Gralith , Sep 26, 2014 :
    Just started doing this weird thing: pick a handset icon to dial, tap center tiny squares to access dial pad, and I get a blank. Use arrow back, tap dial pad and then numbers show up.
    Cleared cache, dalvik, fixed permission - no go.
    I'm on stock latest, rooted.
    Annoying!
  2. a vehicle
    Jelly Bean Sep 26, 2014
    a vehicle , Sep 26, 2014 :
    I don't like lag either. You could close some apps, or reboot your smartphone (just hold down the power button).
  3. Gralith
    Froyo Sep 26, 2014
    It's not a lag. I have to do this every time when I dial, back arrow saves the day, but it's annoying.
  4. a vehicle
    Can you post a screenshot? Press volume down and power at the same time.
  5. Gralith
    Froyo Sep 27, 2014
    a vehicle likes this.
  6. haynes11
    Gingerbread Sep 27, 2014
    Gralith likes this.
  7. Gralith
    Froyo Sep 27, 2014
    Gralith , Sep 27, 2014 :
    Excellent! I remember I changed all 3 animations to 0. I now have changed them to 0.5 and BINGO! It's working.
    Appreciate!
    haynes11 likes this.
  8. haynes11
  9. Gralith
    Froyo Sep 27, 2014
    Now I'm having another issue; when using dialpad for VM or calling any number only partial view of the dial pad Screenshot_2014-09-27-16-13-07.png
    EDIT: Got it all fixed - reboot did the trick :)
  10. a vehicle
    Jelly Bean Sep 28, 2014
    a vehicle , Sep 28, 2014 :
    Awesome, it sounds like an issue with the cache used for the animation. Glad to see it resolved!
