Did OxygenOS 4.5.7 fix Battery Drain?
  1. JaniMous Gingerbread Aug 3, 2017
    JaniMous, Aug 3, 2017 :
    A question to the people that already have 4.5.7 installed, did this update fix the battery drain that has been going on for some time now? I'm still running 4.5.6 and I believe I have some serious battery drain going on, as I'm losing almost 20% in standby/doze mode in less than 7-8 hours.
    Thanks!
    J
  2. AaronStark171 Ice Cream Sandwich Aug 3, 2017
  3. Deactivated User Aug 3, 2017
    CeeTeePee and Spieleckecker like this.
  4. F_Vasu_Shobhit_lBPj Honeycomb Aug 3, 2017
  5. NovinDavis KitKat Aug 3, 2017
  6. F_Yashwanth_Raj_eKHI Cupcake Aug 3, 2017
  7. F_Ayur__Munkuev_bxst Cupcake Aug 3, 2017
  8. G_subham_gupta_ZMHQ Eclair Aug 3, 2017
  9. pps1986 Cupcake Aug 3, 2017
    pps1986, Aug 3, 2017 :
    i m using 4.5.6 version and facing battery drain issue... let's c what happens in 4.5.7
    cornkc3 likes this.
  10. mayursulakhe1991 Froyo Aug 3, 2017
  11. G_Pratik_Dubey_cvUz Gingerbread Aug 3, 2017
  12. dthx Eclair Aug 3, 2017
    dthx, Aug 3, 2017 :
    for me it has solved it, but I cleared the cache in recovery mode right after the update. I loose less than 1% / hour now in stand by. with WiFi/4G on. Yesterday I forgot to turn on Bluetooth, but I don't expect a huge difference...
    Good luck !
  13. G_Bala_Gurunathan_uQKj Cupcake Aug 3, 2017
  14. Asifjaved007 Honeycomb Aug 3, 2017
    Asifjaved007, Aug 3, 2017 :
    I never had this "battery drain" issue, but after the latest update the it has improved in idle time too..
  15. alextiley1 Cupcake Aug 3, 2017
    alextiley1, Aug 3, 2017 :
    Battery life significantly improved with OxygenOS 4.5.7. While listening to music, I only lose between 1 and 2% an hour, with the screen off.
  16. G_Stephen_Smith_BtsB Cupcake Aug 3, 2017
  17. Callmevish Honeycomb Aug 3, 2017
  18. rcauinian Cupcake Aug 3, 2017
  19. mark555055o Honeycomb Aug 3, 2017
    mark555055o, Aug 3, 2017 :
    There is no got damn battery drain. Factory reset, install no apps, and then show me your battery drain....... Yeah, there won't be any. Stop installing stupid apps, people.
    F_Paul_Bamford_ytyA likes this.
  20. kennethgds Eclair Aug 3, 2017
    kennethgds, Aug 3, 2017 :
    Everyone here, rather than telling us that "you think" your OP5 has drained after the update. A screenshot of the battery chart will be good.
