Difference between power saving, balanced & performance?
  1. Ezylryb
    Gingerbread Jul 12, 2014
    Ezylryb , Jul 12, 2014 :
    I have place a setting in the quick panel to change between power saving, balanced & performance.
    Anyone know what changes inside the phone when I switch between these 3 mode?
    Joyyy likes this.
  2. Matt7262
    Ice Cream Sandwich Jul 12, 2014
  3. Nagasaky2x
    Jelly Bean Jul 12, 2014
    Nagasaky2x , Jul 12, 2014 :
    Performance -> Constant maximum CPU frequency (2.4GHz).
    Balanced -> CPU frequency between 300MHz - 2.4GHz
    Power saving -> CPU Frequency between 300MHz - 1GHz.
  4. Ezylryb
    Cool answer! Thanks!
    Other than that, does it change any setting? (wifi, bluetooth, 3g, etc)
  5. Nagasaky2x
    As I have seen it just changes the CPU states. Nothing else, not even GPU.
    Ezylryb likes this.
  6. soonermagic
  7. Ezylryb
    Thanks Pal!
  8. Mark Probert
    Cupcake Jul 13, 2014
  9. manaknights
    Honeycomb Jul 13, 2014
    manaknights , Jul 13, 2014 :
    Gotta leave it on Performance at all times. NEED THE POWER!!!
    rajeshnyk29 and Mark Probert like this.
  10. lutti
    KitKat Jul 13, 2014
  11. defaultess
    Gingerbread Jul 13, 2014
    defaultess , Jul 13, 2014 :
    That's pretty cool. As a current blackberry user these are the kind of things I'm looking forward to.
    Is it possible to link other things such as wifi, bluetooth, etc. in the same quick panel? Maybe changing to power saving disables all of them?
  12. Deactivated User
    Aug 22, 2014
    Joyyy and draa like this.
  13. Grip_then_Slip
    Ice Cream Sandwich Aug 22, 2014
    Grip_then_Slip , Aug 22, 2014 :
    I only see two settings in the Quick Panel: "Battery Saving" or "High Accuracy".
  14. Deactivated User
    Aug 22, 2014
    Grip_then_Slip likes this.
  15. Deactivated User
    Aug 22, 2014
    Joyyy and PuresGift like this.
  16. Grip_then_Slip
    *******, i'm stupid!!!!!!!!!!!!
    Deactivated User likes this.
  17. Deactivated User
    Aug 22, 2014
    Joyyy, MagicMagicD and mlong212 like this.
  18. sdrem00
    Froyo Aug 23, 2014
    sdrem00 , Aug 23, 2014 :
    You can add a toggle in quick settings panel for performance settings. I go to power save when I am not using the phone.
    heidou007 likes this.
  19. Green1230
    Honeycomb Oct 19, 2014
    Green1230 , Oct 19, 2014 :
    Right .. but this would mean, that when needed, the performance in the "Balanced" option would go as high as the performance in the "Performance" option, right? Yet this is not true: when I have my OPO set to Balanced and play a game (for example Asphalt 8: Airborne - and this is not the only game where I have experienced this), the game runs great, but there is some lag in the menus (yes, I have no freakin' idea why in the menus .. as if THIS is the hardware-killing part of an app or what??). If I have my OPO set to Performance and run the game, everything runs smoothly, even the menus. So what's the catch?
  20. MagicMagicD
    MagicMagicD , Oct 19, 2014 :
    @Green1230 It's probably because the menu isn't that demanding so it throttles back but then because it's running at a slower speed it momentarily can't keep up with the demand for more performance, which you perceive as lag.
    If you enable developer options (by clicking on the build number 5 times) you can change the CPU governor, which might give you a better result. I'd suggest you read up on these things before though so you know what you're getting yourself in to.
    Alternatively you could try something like Tasker and have it so that whenever you run your games it automatically switches to Performance mode.
    Joyyy and Green1230 like this.
