Digital zoom of the camera is removed (tap to (1x to 2x) via OnePlus 7
  1. bingi46
    Honeycomb Jun 21, 2021
    bingi46 , via OnePlus 7 , Jun 21, 2021 :
    Tap from 1x to 2x the digital zoom for the camera of the op7 was removed for the andriod 11,the feature was very useful as the user could take milli seconds snapshots during capturing of photos or even during video .
    Now on the andriod 11 update without the digital zoom can't take those snapshots under perfect conditions for me this a game breaking big deal which the digital zoom used to work so fantastic ,Im really disappointed for the OnePlus team as they removed GREAT FEATURE WHICH WAS ALREADY PRESENT ON ANDRIOD 10 ,I hope they fix this
  2. gikkka
    Gingerbread Jun 21, 2021
    gikkka , Jun 21, 2021 :
    Wait. They didn't remove anything, they just changed it a bit. You press the zoom button, a tree appears, press the first one, you have 2x zoom, press the second one, you have 10x zoom. You don't have to move the slider, just click on the tree icon. What is the problem? Extra tap with your finger?
    Artemus. likes this.
  3. bingi46
    They removed tap to 1x to 2x ..it was like that before ..I don't want to get inside that tree option & then drag it down to 2x ,it will be too late for snapshots ,tap from 1x to 2x used to work wanders for me
  4. Tobikage
    Nougat Jun 21, 2021
    Tobikage , Jun 21, 2021 :
    Suggestions go here...
  5. gikkka
    Dude, you need to do two instead of one tapa. This is half a second longer.
  6. bingi46
    Exactly it's longer and the process to get there is to tap & then drag ..instead it was just to tap 1x to 2x back & forth on the os 10 ,matters a lot while making videos ..
  7. gikkka
    It is not necessary to drag. Just tap.
  8. bingi46
    Nope doesn't work if I tap on the 1x icon ,tree option comes up & I'm forced to drag to all over to 2x :(
    U1577104538091 likes this.
  9. gikkka
    It’s strange. What firmware? It works for me on beta 5.
  10. bingi46
    I'm on Stable ota 11.0.2...so they fixed this on beta 5?
  11. gikkka
    Well actually on previous versions I haven't tested this option. But on OB5 it works just like that.
    bingi46 likes this.
