Direct Wi-Fi
  1. Mohamed Hussein
    Eclair Dec 13, 2014
  2. aman360elite
    Ice Cream Sandwich Jan 6, 2015
    #42
  3. ankit khirsariya
    Donut Jan 13, 2015
    #43
  4. vamshibhargava3
    Gingerbread Jan 17, 2015
    vamshibhargava3 , Jan 17, 2015 :
    Same problem with me. Cant find option to share through wifi direct in send/share window.. Even i tried superbeam bt no use.. Sending fails everytm..
    #44
  5. ankit khirsariya
    Donut Jan 22, 2015
    ankit khirsariya , Jan 22, 2015 :
    One plus can connect to other phone with WIFI-DIrect but it cannot transfer the files.....
    And also there are no option of 'Wifi-Direct' while sharing the files from Gallery or File-Manager.....
    This is very annoying.....
    Hope That, the One plus team will solve this problem in next update for which everyone is waiting....
    And maintain their "NEVER SETTLE" theme or reputation....
    #45
  6. ankit khirsariya
    Donut Jan 22, 2015
    #46
  7. gjaouen
    Donut Jan 25, 2015
    gjaouen , Jan 25, 2015 :
    Yes, I confirm too that wifi direct doesn't works with OPO. Those who use Superbeam doesn't use direct wifi but a feature that allow to exchange files via a wifi hot-spot.
    Very annoying.
    #47
  8. prenesh
    Donut Jan 27, 2015
    #48
  9. Bassick
    Honeycomb Jan 27, 2015
    #49
  10. parthav
    Gingerbread Jan 27, 2015
    #50
  11. parthav
    parthav , Jan 27, 2015 :
    use xender it works more then Fine
    #51
  12. parthav
    #52
  13. parthav
    #53
  14. arjansp
    Cupcake May 14, 2015
    arjansp , May 14, 2015 :
    Had the same issue until I read here to try an app.
    I used wifi direct+.
    Worked for me in 5 seconds Where Samsung ROM Android 5.1 with Cyanogenmod 12 did not filetransfer with wifi-direct, this app worked like a charm. No hassle.
    #54
  15. deltaman
    Cupcake Jun 11, 2016
    deltaman , Jun 11, 2016 :
    Wifi direct with opo without 3rd party:
    Stop NFC
    Wifi ON
    Wifi advanced options: WiFi direct
    Search and invite the other smartphone
    The latter have to valid the invitation.
    Go to ES explorator and "send" files you want.
    You will see a 192.XXX group address that you have to valid. Then "send"
    The other smartphone valid the sending and choose the folder he want.
    Easy !
    #55
