disable energy ring via OnePlus 8
  1. Sahiti Patri
    Cupcake Sep 19, 2020
    SANTHOSH6776 likes this.
  2. AlienEye
    OnePlus Accessory Tester Sep 19, 2020
    AlienEye , Sep 19, 2020 :
    Seriously!!!!
    Energy ring is a third party application.
    How could OnePlus do something about it.
  3. Neerajan
    Honeycomb Sep 19, 2020
    Neerajan , via OnePlus 8 , Sep 19, 2020 :
    Are you mentioning to white ring which lights up around the front camera when it is in use?
    If that so then I think it is for a security feature, it doesn't apply any filters. It even lights up when the front camera is accessed by other third party apps such as WhatsApp or Skype.
    Or are you mentioning about the energy ring app from play store? It doesn't behave as you mentioned, the ring light will always be on irrespective of whether you're using the front camera or not. If your issue is with the energy ring app, then it is advisable to contact the app developers. There is nothing that people from this community can do.
