Disable Power Button on Lock Screen?
  1. andyandrw
    Gingerbread Jun 28, 2016
    andyandrw , Jun 28, 2016 :
    Hello I have Cerberus anti theft app and the option to block the power button on the lock screen doesn't work. How can I block this menu of turning off the device on the lock screen? (To prevent a thief from stealing it) I am using android 6.0 / OP2.
  2. cohaolain
    Honeycomb Jun 28, 2016
    cohaolain , Jun 28, 2016 :
    There was an app I used to have that did it, search for it on the play store but you need root. Basically it cancels the menu out before you can use it for anything.
    Can't find it right now sorry mate :( hopefully you have more luck than me!
    Good luck!
  3. andyandrw
    I really don't like to root, I hoped there was an option to do without rooting. Cerberus promises but it doesn't work. I have also tried Smart Lock Screen also doesn't work. https://www.cerberusapp.com/help/es/27 Supposedly works on other android devices. dunno why not in op....
  4. cohaolain
    Probably Oxygen OS....
    Can't see a way beside rooting to be honest...
  5. andyandrw
    Gingerbread Jun 29, 2016
  6. andyandrw
    Gingerbread Jul 2, 2016
  7. dssainaveen
    Cupcake Apr 25, 2017
