Disable WiFi Calling on OnePlus 7 Pro T-Mobile
  1. JonathanTo
    Cupcake Sep 23, 2020
    JonathanTo , Sep 23, 2020 :
    Hello all,
    How do I turn off WiFi calling on my OnePlus 7 Pro? I was looking at some tutorials online but I couldn't find the place where I could clikck on Sim 1 and disable WiFi calling from there. Here's a screenshot of my Sim Setting page:
    Jonathan
  2. mojoyoyo77
    Assistant Head Moderator Assistant Head Moderator Sep 23, 2020
    mojoyoyo77 , Sep 23, 2020 :
    Tap on sim card: SIM name/"T-Mobile - US"... And the settings will open
    Artemus. likes this.
  3. JonathanTo
    Cupcake Sep 24, 2020
    JonathanTo , Sep 24, 2020 :
    I've tried but only this shows up
  4. mojoyoyo77
    Assistant Head Moderator Assistant Head Moderator Sep 24, 2020
  5. mojoyoyo77
    mojoyoyo77 , Sep 24, 2020 :
    Thread moved to US / T-Mobile regional forum.
    Possibly here you can get a better answer
  6. keithnyc
    Marshmallow Moderator Sep 24, 2020
    keithnyc , Sep 24, 2020 :
    Hey Jonathan,
    Hmmm, that's different from my setup as well. Have you stopped into a TMobile store to ask them? They should be able to help
    Artemus. and mojoyoyo77 like this.
  7. #7
  8. stevenWa
    Cupcake Oct 17, 2020
  9. Jg9907
    Cupcake Oct 18, 2020
    Jg9907 , Oct 18, 2020 :
    Here's an imgur gallery with the wifi calling setting location. Also your settings has a search bar at the top you can type wifi calling into it.
    WiFi calling setting https://imgur.com/gallery/AyKoIE6
    Source: T-Mobile rep with a OnePlus 7 pro
