262
ROM [DISCONTINUED]Oneplus 2 Stock rom collection [UPDATED: 22/09]
Thread Status:
Not open for further replies.
  1. MNDTrix
    Honeycomb Sep 21, 2015
    MNDTrix , Sep 21, 2015 :
    Good luck, let us know the result.
  2. MNDTrix
    I am little confused about the steps, clarification would be awesome :D
    If I wanna install OTA zips should I do just as you say like,
    Or, it should be like,
    1) Download the latest Full ROM zip to your device
    2) Download the latest OTA zip to your device
    3) Boot to recovery (twrp)
    4) Take a nandroid backup (if you are using custom recovery like TWRP)
    5) Wipe system, cache, dalvik (recommended)
    6) Flash the Full ROM zip first (you can flash this on top of your current install)
    7) Flash the OTA zip after the FULL ROM
    8) Flash other zips you need (SuperSu, Exposed etc)
    9) Wipe Cache/Dalvik Cache
    10) Reboot the device to the OS
    By following either steps, will I lose any of my apps and/or data?
    Thank you for your time, great post by the way :D
  3. Superpully
    Ice Cream Sandwich Sep 21, 2015
    Superpully , Sep 21, 2015 :
    Not working it says "error"... I think i will wait for OTA then
  4. MNDTrix
    Hmmm... pretty annoying! :(
  5. ghul21
    Donut Sep 21, 2015
    ghul21 , Sep 21, 2015 :
    Omg...steps are simple..
    If you have a stock recovery with no root just put zip into your internal memory. Reboot to recovery and flash.
    When you was rooted with twrp (like me)
    1. You can restore stock backup (of course you are smart and you make a backup before you rooted your device ... Like me..) when you restore it just reboot and when twrp ask you to disable twrp...don't Swype... Just disable... You reboot to fresh unrooted system. Then reboot to recovery, flash the zip. Now you have 2.1 on board. Then (if you want) flash twrp with fastboot and root the device. It takes 10 min of your precious life.
    2. See OP. It's well said what you have to do.
  6. Nikolis1
    Gingerbread Sep 21, 2015
    Nikolis1 , Sep 21, 2015 :
    If I'm already on 2.02 can't I just flash ota 2.1 instead of... Flash 2.02 full Rom then the 2.1 ota
  7. Magnetic Nerd
    Jelly Bean Sep 21, 2015
    Magnetic Nerd , Sep 21, 2015 :
    Yes you can as long as you're not rooted.
  8. agodo
    agodo , Sep 21, 2015 :
    when will the 2.1 full ota come out? is there a way to install the ota via twrp if i am rooted?
    thanks
  9. jma9454
    Honeycomb Sep 22, 2015
    jma9454 , Sep 22, 2015 :
    So I know you will just tell me to do it the right way, but it's just the recovery that's keeping the update from happening. Is there some recovery zip we can flash before flashing the ota? I know that the recovery is an img file, but I thought there was a way to just flash the recovery? Sorry if this is a clear no-no, I haven't done much flashing since I got my opo last year, so I need a refresher...
  10. Ivanpoocky13
    KitKat Sep 22, 2015
    Ivanpoocky13 , Sep 22, 2015 :
    This worked out for me :)
  11. dslate69
    Cupcake Sep 22, 2015
    dslate69 , Sep 22, 2015 :
    Yep that's what I did. It worked like a charm.
  12. tsenkel
    tsenkel , Sep 22, 2015 :
    Firefox is blocking the full rom download of 2.02 saying it contains malware. Can this just be ignored?
  13. tsenkel
    The block occurred when downloading from onedrive but did not occur when using dropbox. Might want to check to see if the checksums match; was too lazy to check myself.
  14. madsatan
    Donut Sep 22, 2015
    madsatan , Sep 22, 2015 :
    somehow i deleted all my os and blah blah blah
    so i sideload my opt with OxygenOS 2.0 ( OnePlus2Oxygen_14_OTA_002_all_1507251956_wipe.zip)
    and i got my home button back ...yay
    then flashed the OxygenOS 2.0.2
    still have a home button
  15. Samin007
    Samin007 , Sep 22, 2015 :
    Not done those Steps... But working great..!!!
    MNDTrix likes this.
  16. lukez
    Gingerbread Sep 22, 2015
    lukez , Sep 22, 2015 :
    Just want to confirm something here...
    Just got my phone with 2.0.3 pre-installed. I installed TWRP and rooted the device before I saw this update :(
    So I need to wipe system/cache/dalvik, flash FULL rom of 2.0.2 on the first page, flash OTA 2.1?
    Does that sound right?
  17. iRajeshRajput
    iRajeshRajput , Sep 22, 2015 :
    Guide to flash the latest Oxygen OS 2.1 OTA zip file on the rooted Oneplus 2 with the help of TWRP recovery.
  18. soshi89
    soshi89 , Sep 22, 2015 :
    Sounds about right.
  19. njain2686
    njain2686 , Sep 22, 2015 :
    Thanks man. Worked perfectly...:D
    Now I only have to set up my xposed modules again.:mad:
  20. iRajeshRajput
