262
ROM [DISCONTINUED]Oneplus 2 Stock rom collection [UPDATED: 22/09]
Thread Status:
Not open for further replies.
  1. Corvinus77
    Honeycomb Sep 22, 2015
    Corvinus77 , Sep 22, 2015 :
    Do it exactly like here in this Video:
    Everything works fine. I´ve updatet from Stock 2.0.3 with Root & TWRP to 2.1.0.
    Regards
    jnguygc and MNDTrix like this.
  2. drmrahul
    Froyo Sep 22, 2015
    drmrahul , Sep 22, 2015 :
    i have rooted op2. i used twrp temporary. so i have stock recovery. i unrooted using supersu and uninstalled it. root checker now shows not rooted now. i tried to update using this 38.6 mb file using stock recovery. But it failed. any advice. i don't wanna download that 1.1 gb file
  3. iRajeshRajput
    iRajeshRajput , Sep 22, 2015 :
    Yes.... You have to flash it again and install the 2.1 file..... otherwise you will get an error.
    rainoldo likes this.
  4. iRajeshRajput
    No you can't flash it......
    You have to install the FULL ROM first ( With this way the phone is unrooted) and flash the 2.1 OTA..
    See this video:-
  5. EddyOS
    Froyo Sep 22, 2015
    drmrahul likes this.
  6. inffy
    KitKat Sep 22, 2015
  7. inffy
    KitKat Sep 22, 2015
    taherkhant and Bartnl like this.
  8. rctempire
    Gingerbread Sep 22, 2015
    rctempire , Sep 22, 2015 :
    Boot into TWRP
    Flash the full OxygenOS 2.0.2 zip:
    OnePlus2Oxygen_14_OTA_006_all_1508211811.zip
    Flash the 2.0.2 > 2.1 OTA update zip:
    OnePlus2Oxygen_14_OTA_006-008_patch_1509191929.zip
    Flash SuperSU
    UPDATE-SuperSU-v2.46.zip
    Reboot system "Swipe to disable" NOT "Not disable"
    Update worked great and no issues. Updated to 2.1 and seems alot better.
  9. add1ct3dd
    add1ct3dd , Sep 22, 2015 :
    Presume now the full 2.1 rom is available, we can disable SU, install FULL rom only (2.1), reflash SU and then done?
  10. divinityQQ
  11. bootman
    bootman , Sep 22, 2015 :
    I'll let you know in a few, flashing now.
  12. bootman
    It works!
    Now let me see if they fixed the Bluetooth issue (not uploading contacts and call history to my car)
    divinityQQ likes this.
  13. add1ct3dd
    Anyone tested OTG with this update? Haven't seen anyone get it working on earlier versions..
  14. pgravili
    Ice Cream Sandwich Sep 22, 2015
    pgravili , Sep 22, 2015 :
    Unfortunatly that error still perxists :(
  15. bootman
    Yeah just tested it and it is still there.
    This will cause a bunch of returns since it makes handsfree calling difficult at best.
    It does work in the CM based ROMs but they have other issues.
    The two may have to go back.......
  16. pgravili
    I hope they'll solve the issue as soon as possible!
  17. Buzzrr
  18. ksavai
    ksavai , Sep 22, 2015 :
    No.
    only if you factory reset before flashing....
    note - Wiping cache dont delete any user data
    Buzzrr likes this.
  19. add1ct3dd
    I flashed the Full 2.1 OTA from 2.0.2 - super slow. Got 40k in the Antutu benchmark too, it felt laggy to use, something not quite right, so I'm going to download the 2.0.2 full, flash that, then flash the OTA package after.
  20. Superpully
    Superpully , Sep 22, 2015 :
    Isn't there a way to install via adb the complete image file?
