3
Discord Screen share on mobile - Audio/Sound not working
  1. anurag_biyani
    Cupcake Dec 22, 2020
    anurag_biyani , Dec 22, 2020 :
    When I share screen on Discord app with my mobile - Audio/Sound is not going and only the screen gets shared. I have checked with other mobile it is working. is there any hardware issue in One plus? Need help in this
  2. Artemus.
    Community Hero 2020 Dec 22, 2020
    Artemus. , Dec 22, 2020 :
    Do you have microphone set as the audio source?
  3. anurag_biyani
    yes and when other participant share the screen.. I can listen.. but when I share sound is not shared and only the screen gets shared.
  4. Artemus.
    That seems like something you'd have to discuss with Discord. My guess is, it's using the internal screen recorder to broadcast and since you're limited to either screen audio or your mic, I think that's what's happening here.
  5. anurag_biyani
    anything can be done.. my friends are not facing the issue.. I checked all settings ?
    EneerGy likes this.
  6. Artemus.
    Check with Discord, as I said.
  7. piyushix
    Donut Dec 29, 2020
  8. O1599150636081
    Cupcake Mar 2, 2021
    O1599150636081 , Mar 2, 2021 :
    Same problem here (OnePlus 8T)
  9. piyushix
    Donut Mar 13, 2021
  10. Artemus.
    Community Hero 2020 Mar 13, 2021
    Artemus. , Mar 13, 2021 :
    It's an advertisement, likely a bot.
  11. PRINCECHHABRA
    Cupcake Apr 19, 2021
    PRINCECHHABRA , via OnePlus 7T , Apr 19, 2021 :
    Did you get the solution for it? Facing the same issue on my 7T
  12. G1605775460269
    Cupcake Apr 26, 2021
    EneerGy likes this.
  13. ALSHAD.S
    Cupcake Jun 11, 2021
    EneerGy likes this.
  14. EneerGy
    EneerGy , Jun 11, 2021 :
    Hello, still no solution since December ? :( same issue here, Oneplus 8T, Android 11, checked everything already, I'm the only one with this problem within my friends, and the only one with a OnePlus... Pls find us a solution OnePlus.
  15. Artemus.
    Community Hero 2020 Jun 11, 2021
    Artemus. , Jun 11, 2021 :
    Like I said, check with Discord.
  16. J1624001384731
    Cupcake Jun 18, 2021 at 8:38 AM
    J1624001384731 , Jun 18, 2021 at 8:38 AM :
    Discord screen share no audio is a common issue that occurred when using this platform even in 2021. But here some steps are given to fix this issue. It revealed that the problem was caused by some changes that were introduced to Google Chrome’s audio infrastructure.
