Disney+ app not compatible with OP7pro?!?
  1. elanglois
    Lollipop Nov 12, 2019
  2. #22
  3. elanglois
    elanglois , via OnePlus 7 Pro , Nov 12, 2019 :
    No. I'm not asking you if it will. I'm asking if you noticed.
    There is no issue installing this app on a OP7Pro. Its not blocked in the play store.
  4. Ewing33855
    Eclair Nov 12, 2019
    Ewing33855 , Nov 12, 2019 :
    you have the unlocked model? also which carrier do you use I'm on Verizon I don't think it's a carrier issue but worth asking.
  5. mptpro , via OnePlus 7 Pro Nebula Blue , Nov 12, 2019 :
    I misunderstood. No, it's not working for me. apparently others are having the same issue. there is a Reddit thread where people are thinking it's a security no issue when using 10 beta 5 (which I am)
  6. elanglois
    Unlocked Model??? Wow. Thats so weird on a Oneplus forum. Yes. I buy from Oneplus, not T Mobile. And carrier won't matter, but I'm on Mint.
  7. elanglois
    You mean only Beta 5 is the issue?
    Wanna fix it?
    Magisk might do the trick [e]1f603[/e]
  8. Jeffrey_Alan_Foster
    Cupcake Nov 13, 2019
  9. arabinow
    Froyo Nov 13, 2019
  10. arabinow
    Froyo Nov 13, 2019
  11. G_Benjamin_Woods_Crzt , via OnePlus 7 Pro Nebula Blue , Nov 13, 2019 :
    Got this from a Samsung forum but it worked for my OnePlus 7 Pro. Leave the play services beta and reboot. Wipe cache of both Play Services and the Google Play Store and hopefully it will work for you as well. I just quit all of my betas through the Play Store settings but I don't think that's necessary. Best of luck to you all
    Ewing33855 likes this.
  12. Jeffrey_Alan_Foster
    Jeffrey_Alan_Foster , Nov 13, 2019 :
    Okay, I just downloaded the app and it's working. I guess this was just a Disney glitch.
  13. Ewing33855
    Eclair Nov 13, 2019
    Ewing33855 , Nov 13, 2019 :
    I can confirm this works. I was on on a Droid life forum and someone had mentioned the same thing. I left beta and now it went from not compatible to now compatible. downloaded! success!
    Are you enrolled in Google Play Services beta? If so, leave beta, clear cache, reboot phone. Should be able to download with about 15 min after that.
    Got this from a Samsung forum but it worked for my OnePlus 7 Pro. Leave the play services beta and reboot. Wipe cache of both Play Services and the Google Play Store and hopefully it will work for you as well. I just quit all of my betas through the Play Store settings but I don't think that's necessary. Best of luck to you all​
    G_Benjamin_Woods_Crzt likes this.
  14. ccoerber
    Cupcake Nov 14, 2019
    ccoerber , Nov 14, 2019 :
    I have the same issue on my OnePlus 5. It says it's not compatible with my device on the Play Store. I downloaded the app from an apk site and was able to install it and watch videos that way.
  15. TobeRobert
    Froyo Nov 14, 2019
  16. BKiv
    Eclair Nov 17, 2019
    BKiv , via OnePlus 6T , Nov 17, 2019 :
    I'm having same issue. OnePlus 6T TMobile converted to international. My play store says not certified... any ideas on how to get certified? I tried clearing cache and data...
  17. danielhall
    Donut Nov 18, 2019
    danielhall , Nov 18, 2019 :
    Hi OP, you can install APKPure to sideload the app. https://apkpure.com/. Worked for me on my unlocked OP 7 pro on the current stable build 10.0.1 gm21aa.
  18. TobeRobert
    Froyo Nov 22, 2019
    TobeRobert , via OnePlus 7 Pro , Nov 22, 2019 :
    Be aware that APKPure can prevent Google Playstore from updating apps that are currently installed. Happened to me until I uninstalled APKPure. Then Playstore worked just fine.
    #38
