158
Display Deep Dive Pt.2 - OnePlus 7 Pro Supports HDR 10+
  1. elanglois
    Lollipop May 28, 2019
    elanglois , May 28, 2019 :
    10000 nits? Do you need a lead lined suit for the radiation?
    mattyelle1 likes this.
  2. mattyelle1
    Gingerbread May 28, 2019
    mattyelle1 , May 28, 2019 :
    So it seems that the issue was with the display setting being on Natural...I switched to AMOLED Wide Colour Gamut and it now plays in HDR...
    Screenshots are taken in SDR so I can't show the sky varying gradiant from my previous example, but here is Jason Statham's face with details on shadows...
  3. elanglois
    How can you be sure that Plex isn't doing a re-encode, like to drop from 4K to 1440p and losing the HDR during the process?
    Copy the file to the phone and play with VLC
  4. mattyelle1
    That screenshot doesn't do it justice because in SDR...it lost details compared to HDR10.
    How do we report this to OnePlus? The screen should automatically switch to AMOLED Wide Gamut when playing HDR videos...
  5. elanglois
    I would use DCI-P3. Amoled wide will be oversaturated. It's the max the phone will do
  6. mattyelle1
    Ok. How do we report this to OP staff? The display should switch to DCI-P3 or AMOLED Wide Gamut automatically when playing HDR...
  7. elanglois
    NOOOO .... it switches if an ICC profile is detected. If your recording lost that, it can't switch. Most likely the issue is how the file is encoded on your server.
    And Amoled wide isn't any standard. [e]1f603[/e]
  8. elanglois
    It switches fine on all my content. Where did you get yours?
  9. mattyelle1
    Ya I know...but are you sure AMOLED Wide Gamut isn't just what OP calls rec.2020? I mean the OP 7 Pro fills DCI-P3 colour space and spills into rec.2020
    Michelin18 likes this.
  10. mattyelle1
    Torrent. It's a 20Mbps bitrate file ripped in HDR10 by a reliable transcoder...it's probably the best HDR file I've viewed on my x900f since it's full of dark scenes with bright LED lights.
  11. mattyelle1
  12. elanglois
    http://www.displaymate.com/OnePlus_7Pro_ShootOut_1P.htm
    At 111% of DCI-P3 it's not quite rec.2020, its just the panel's natural color without correction. Its detailed in the link
  13. elanglois
    Night mode will turn off your color profile switching. DC Dimming may affect color when brightness is dim
  14. elanglois
    So .. some bootleg illegal copy ripped by ʾsome guy'. I'd not trust that the file was standards compliant, but in this case, I'd say put it back to Natural with Night Mode off and DC Dimming off and see how it goes
  15. mattyelle1
    Like I said, it plays back great on my x900f...so it's not the file. yes I'm testing
  16. elanglois
    The wonderful thinf about standards is no one complies to it 100%. The behavior when violated will vary from device to device. You never know whats going on without looking at the bits
  17. mattyelle1
    No display in 2019 fills rec.2020....its the holy grail. According to DisplayMate testing it spills out 11% out of DCI-P3 and into rec.2020. The only way to viewcthec11% extra colours on OP 7 Pro would be to watch in rec.2020. I'm 99% sure that's AMOLED Wide Gamut.
  18. elanglois
    Well yes. But unless you have content for rec.2020, you will just be oversaturating your content by 11% Seems kinda pointless
  19. mattyelle1
    Isn't there? Ahem Dolby Vision ahem
  20. Michelin18
    Eclair May 28, 2019
    Michelin18 , May 28, 2019 :
    so to play HDR has amole wide color has to be enable??
