158
Display Deep Dive Pt.2 - OnePlus 7 Pro Supports HDR 10+
  1. Michelin18
    Eclair May 28, 2019
    Michelin18 , May 28, 2019 :
    mine doesnt have that option
    ntcs is the same, i doubt it
  2. mattyelle1
    Gingerbread May 28, 2019
    mattyelle1 , May 28, 2019 :
    Ok I did some further testing with that same file again (The Meg in HDR10 20Mbps)...
    The issue was Night Mode.
    You probably should try changing between DCI-P3 and AMOLED Wide Gamut to see what best optimizes your viewing experience. I think on Netflix and Amazon Prime I would try AMOLED Wide Gamut and for my Plex files dci-p3
  3. mattyelle1
    OP 7 Pro? In what country are you? I'm not sure what that is..perhaps an acronym more common in your country
  4. elanglois
    Lollipop May 28, 2019
    elanglois , May 28, 2019 :
    No. Natural should work. If you must switch it manually, DCI-P3 is the correct colorspace for most HDR content. Be sure to have Night mode and such off, and no word on the effect of DC dimming yet
    mattyelle1 likes this.
  5. mattyelle1
    I found DC Dimming doesn't affect HDR. For me it was just night mode.
    elanglois likes this.
  6. elanglois
    NTSC is a US Standard that NO device adheres to. Your next software update will change NTSC to Amoled Wide (basically running balls-out)
    Michelin18 likes this.
  7. Michelin18
    Eclair May 28, 2019
    mattyelle1
    OP 7 Pro? In what country are you? I'm not sure what that is..perhaps an acronym more common in your country​
    US
    yes is the 7 pro
    but ill try the first option,
    bump up the brightness to max when playing hdr?
  8. elanglois
    Your phone doesn't support Dolby Vision! You can't just turn on a higher range color gamut and expect it to be Dolby Vision. There is whole other data stream that compliments the HDR10 info that you don't have access to.
    Wanna beg Oneplus to license Dolby Vision? I have it on my TV and it does look better than plain HDR.
  9. elanglois
    Set phone to Natural and it will auto-change for you to whatever is correct for the current content being displayed. Set brightness to whatever is comfortable to you, but the higher brightness gives you a wider range
  10. mattyelle1
    Yes max. I find it makes a difference in both dark and bright areas
  11. mattyelle1
    Your right, for OP 7 Pro...is HDR10+ only DCI-P3 as well?
    I'm sure your aware but just in case...DV content will play down as HDR10 on any display without certification from Dolby. No OP will never pay for DV...that's why they are onboard with Samsung for HDR10+ who also don't like paying for it.
  12. elanglois
    Yep. The DV stream is an extra file stream that adds to the existing HDR10 stream. The rec.2020 could be done by plain HDR, but the cinemas are using DCI-p3 so thats generally what you get for all 3.
    HDR10 has a single metadata for the TV to optimize the color. It handles up to 1000nits, 10 bit color.
    HDR10+ allows frame by frame metadata so that you can optimize per scene. Plus, It goes to 4000nits
    DV is 12 bit color and up to 10000 nits, also dynamic metadata.
  13. mattyelle1
    DV is overkill since no display available on the market can show 10,000 NITs and Rec.2020....not even close. I think about 3,000 NITs and not even half of rec.2020. HDR10 was a little lacking due to 1,000 NIT max...so HDR10+ makes sense...companies likely to get onboard with time to kill DV
  14. elanglois
    The scene by scene metadata was the biggest difference until HDR10+, and DV still has 12 bits per subpixel over 10. That's about 64 times the number of colors! Not that I could see it, but I do like my DV Blurays [e]1f603[/e]
  15. Michelin18
    Eclair May 28, 2019
    thats why i didnt pick it.
    i try natural, the HDR went away. i try NTCS, it seems to be working better than p3 and natural
  16. elanglois
    NTSC is just an old TV Standard. I've not had a problem with Natural not switching ... maybe after your next update? DCI-P3 is what movies are recorded in now.
  17. mattyelle1
    Pal is your TV a 12-bit panel?? I mean common there is no display on consumer market in 12-bit...thanks to 10-bit display over past few years we now have wide colour gamuts. Your wasting your money on DV blurays. They play down to 10-bit colour spaces
  18. elanglois
    Actually there is more support for DV than HDR10+. In fact, I don't know that my TV supports HDR10+, only DV and HDR10. The scene based optimizations do make a difference. And I've yet to see a movie that had an HDR10+ version available at a cheaper price than the DV version
    Seriously, most HDR discs have DV
  19. Michelin18
    Eclair May 28, 2019
    wait, isn't hdr10+ from Samsung and dolby is from dolby?
    is like a battle ground to standardize one
    honestly I like the one that is free
  20. mattyelle1
    That's true meta data helps. More details in both dark and bright scenes...but you don't really need meta data if you have an OLED...which can't produce much over 1,000 NITs. It can play all shades of colours at a fixed range
