Gigimouse81 , via OnePlus Nord , Aug 1, 2020 : Display Issue are Back. This Is my NORD. View attachment 1387097 View attachment 1387098 View attachment 1387099
AlienEye , via OnePlus 6 , Aug 2, 2020 : Common display issues on Amoled panels as stated by Oneplus. It is bad though.
jason.sundaram , via OnePlus Community App , Aug 2, 2020 : Mine Nord looked same as yours. I just requested to return and get a full refund.
Fa_y_izz , via OnePlus 5 , Aug 3, 2020 : This issue already have oneplus 5 after update android 10 ☹️
Kishore_n , via OnePlus Nord , Aug 3, 2020 : Is this a software issue or hardware issue? Even i am also facing the same.
Lakshay2367 , via OnePlus Nord , Aug 4, 2020 : They said that it might be software issue and will be fixed in the OTA soon. Wish for that to drop soon
Nirmal_Jaiswal , via OnePlus 6 , Aug 4, 2020 : this is in my phone View attachment 1388872 View attachment 1388871
gokulkpv97 , via OnePlus Nord , Aug 4, 2020 : Same issues here! Just received the nord and was happy But once I opened chrome and this issue popped up. The grey background in chrome helped me note out this issue Will there be an update to resolve this? Or is it better to return the device?
H1593772403132 , via OnePlus 8 , Aug 4, 2020 : There wont be any software coming i am also here so much disappointed by purchasing op8
Gigimouse81 , via OnePlus Community App , Aug 4, 2020 : I sent back Nord for replacement. Is an hardware problem and can t Say Is possible fix with software.... I gas sane problems on S10 Lite and my Phone was repaired (replace screen) After repair was Perfect, same software
gokulkpv97 , via OnePlus Nord , Aug 4, 2020 : Thanks dude. I have also asked another friend of mine who bought the Nord and she hasn't got any issues with it! Maybe it's a hardware issue for some stock!
KASHISH_PURI , via OnePlus 8 Pro Ultramarine Blue , Aug 4, 2020 : Any horizontal line (black band) visible on your unit??
KASHISH_PURI , via OnePlus 8 Pro Ultramarine Blue , Aug 4, 2020 : Any horizontal line (black bar) visible on your unit??
KASHISH_PURI , via OnePlus 8 Pro Ultramarine Blue , Aug 4, 2020 : You need to lower the brightness at minimum!!! Post that open incognito mode and close all tabs and then check!!! Do check and let me know
fromsophie , via OnePlus Community App , Aug 4, 2020 : It's a common issue with AMOLED displays unfortunately. Best bet is to send back to OP to get a replacement
gopikrishna117 , via OnePlus Nord , Aug 5, 2020 : Bro, can u tell me the manufacture date of ur frnds product
