DISPLAY ISSUE
  1. Adithya Parashar
    Froyo Nov 7, 2018
    Adithya Parashar , Nov 7, 2018 :
    I've been noticing this display issue lately . The notch is being displayed and all apps have been set to default notch usage and even with that some part of the image is cropped out for some reason in some apps . I'll include screenshots of some of the apps where this is noticed evidently .This wasn't an issue with the OnePlus 6 or 5t I have used . If this can be solved with some minor tweaks ,let me know . And the play store notifications aren't being shown even though the permissions have be granted and I haven't blocked notifications form it .
  2. jettlemania
    Donut Nov 7, 2018
    jettlemania , Nov 7, 2018 :
    I don't immediately see your issue in the screen grabs I see, but you might look at your Settings>Display>App display in full screen settings.
  3. ADITI_
    Cupcake Nov 8, 2018
    ADITI_ , Nov 8, 2018 :
    I tried this but still no change, I can't view the whole thing.
    Adithya Parashar likes this.
  4. GopalB.
    Nougat Nov 8, 2018
    GopalB. , Nov 8, 2018 :
    You removed those apps from here right???
    Also use reply button!!!
  5. ADITI_
    Cupcake Nov 8, 2018
    yes, I removed the apps, but still no change
  6. GopalB.
    Nougat Nov 8, 2018
    So after removing those apps, the notch part for the app must be just a black bar right???
    So what parts are missing???
    Sides???
    Like the one from the main post???
    And what all apps are suffering???
  7. ADITI_
    Cupcake Nov 8, 2018
    The sides are missing, and the most effected app is Instagram.
  8. Adithya Parashar
    Froyo Nov 8, 2018
    Adithya Parashar , Nov 8, 2018 :
    check this one . it's from Snapchat and the bottom bar ceases to exist . Don't know if this can be altered by the end user
  9. GopalB.
    Nougat Nov 8, 2018
    Are your own stories getting affected too???
  10. Adithya Parashar
    Froyo Nov 8, 2018
    texts are not completely displayed .. some utility parts are missing from some apps . For instance in PUBG mobile , the corners are cut out and is not displayed completely
  11. GopalB.
    Nougat Nov 8, 2018
    My guess is that it might be due to the screen size...
  12. Adithya Parashar
    Froyo Nov 8, 2018
    never happened with my OnePlus 6 or 5t . I've seen oppo phone with the waterdrop notch .. it doesn't happen there ‍♂️
  13. ADITI_
    Cupcake Nov 8, 2018
    Yes
  14. GopalB.
    Nougat Nov 8, 2018
