" Display issues "
  1. RaghulCopz1434 Froyo Jul 3, 2018
    RaghulCopz1434, Jul 3, 2018 :
    Its really very bad to experience like this display problem , I was keep using my mob past 3 to 4 hours the display suddenly became black in half a side and touch doesn't works ,after 1 min it saying me to close or wait for the particular app .
    What's happening !?
  2. Tobikage Nougat Jul 3, 2018
  3. RaghulCopz1434 Froyo Jul 3, 2018
    Was watching YouTube videos and it's my 6th smart phone I think so ?
  4. Tobikage Nougat Jul 3, 2018
  5. RaghulCopz1434 Froyo Jul 3, 2018
  6. Tobikage Nougat Jul 3, 2018
    Tobikage, Jul 3, 2018 :
    So this is somehow a display issue than an app issue ?
    lutti likes this.
  7. RaghulCopz1434 Froyo Jul 3, 2018
    What you are saying yaar , it's obviously a display issue if not my screen would not been black one side and clear another side and touch Even didn't work for 1 to 2 min , was scared something happened to touch .
    Have anyone felt this same problm ? ( Comment it )
  8. KeepTransisting The Lab - OnePlus 7 Pro Reviewer Jul 3, 2018
  9. RaghulCopz1434 Froyo Jul 3, 2018
  10. RaghulCopz1434 Froyo Jul 3, 2018
  11. Taskman Ice Cream Sandwich Jul 3, 2018
  12. G_Prakash_Diwakar_Yovv Honeycomb Jul 3, 2018
  13. RaghulCopz1434 Froyo Jul 3, 2018
    No I'm using avast mob security app !?
    Is there will be any issue using those security apps ?
  14. G_Prakash_Diwakar_Yovv Honeycomb Jul 3, 2018
    G_Prakash_Diwakar_Yovv, Jul 3, 2018 :
    yes sometimes we can have. Since security apps also do lots of things like battery management , process management etc. Check after uninstalling that.
  15. RaghulCopz1434 Froyo Jul 3, 2018
    That's good to hear , but instead of those apps what I can use for clearing my cache or junk files ?
  16. G_Prakash_Diwakar_Yovv Honeycomb Jul 3, 2018
    u can use google file go. or sometimes clean ur cache from recovery.
  17. RaghulCopz1434 Froyo Jul 3, 2018
    Thanks buddy for ur caring reply .
    Have a nice day ..,
  18. ArmataReloaded Jelly Bean Jul 3, 2018
    ArmataReloaded, Jul 3, 2018 :
    RaghulCopz1434
    Have anyone felt this same problm ? ( Comment it )​
    An application crashed most likely, has nothing do to with your screen. It's like when your windows device starts freezing if a heavy programm is crashing. Uninstall the app which crashed and you should be good to go.
    And uninstall your security apps. Don't visit p*rn websites and you are fine.
  19. RaghulCopz1434 Froyo Jul 3, 2018
    But I need that app most commonly all use it ( YouTube )
    Can do this better I should uninstall it and should install it again with new updates !?
  20. RaghulCopz1434 Froyo Jul 3, 2018
    Nothing to visit in porn websites dude but thanks for ur concern !
