Display lcd glass broken,i have warranty will i get replacement?
  1. Prinju
    Froyo Mar 17, 2018
  2. Prinju
    Froyo Mar 17, 2018
  3. G_VINEET_CHAURASIA_VKTp
    Froyo Mar 17, 2018
    G_VINEET_CHAURASIA_VKTp , Mar 17, 2018 :
    no because liquid and damage protection are not included in the warranty
    servify provide liquid and damage protection warranty at additional cost of 1500 rs
    if you have this , then might be a chance to get a lcd replacement
  4. BobbyV8_
    The Lab² Reviewer - Insta360 GO 2 Mar 17, 2018
    BobbyV8_ , Mar 17, 2018 :
    Physical damage is not covered under warranty. I'm afraid you wouldn't have purchased the damage protection did you?
  5. Prinju
    Froyo Mar 17, 2018
    Prinju , Mar 17, 2018 :
    no
  6. BobbyV8_
    Then there is no option that you can get it replaced for free. Even if the touch is working, you need to replace the set - Screen + touch panel as this comes bundled.
  7. Prinju
    Froyo Mar 17, 2018
    what would be the cost?
  8. BobbyV8_
    I won't be able to tell you that. They're charging based on the location. It might be anywhere from Rs. 7000 to 13000 in India. Contacting your nearest Service centre can give you exact details.
  9. Saikumar7
    Ice Cream Sandwich Mar 17, 2018
    Saikumar7 , Mar 17, 2018 :
    change the glass lens if display and touch is working..!! it costs u around 1500rs including repair!!
    PG_Guru_Teja likes this.
  10. PG_Guru_Teja
    Eclair Sep 29, 2021
    PG_Guru_Teja , via OnePlus 5 , Sep 29, 2021 :
    Thanks for the info, does official one plus service does that or have to rely on third party service?
    My one plus 5 glass is broken but touch and display works well
