7
Display network speed beside notch
  1. Prasath Siva
    Cupcake Jul 2, 2018
    Prasath Siva , Jul 2, 2018 :
    I was wondering is there anyway to make the OnePlus 6 display network speed on the status bar all the time, without having to pull down the notification bar everytime to view it. Can the same also be done for the battery percentage.
  2. kaghedo
    Jelly Bean Jul 2, 2018
    kaghedo , Jul 2, 2018 :
    Battery 100% can be set but not sure of the speed thing
  3. deasom
    Honeycomb Jul 2, 2018
    deasom , Jul 2, 2018 :
    not enough room x.xx k/s takes up a lot of space. u also have WiFi, 4G bars, and battery on that side.
  4. R1531953270500
    Cupcake Jul 18, 2018
    R1531953270500 , Jul 18, 2018 :
    it might seem not enough space. but if you had seen an oppo f7, it has pretty much the same notch as op6's and it shows the speed, the batt %, and the wifi and other stuffs. i hope op6 could copy its cousin. it shouldn lt be hard for op6 to do that in the next update like the the batt %.
    impop likes this.
  5. Artemus.
    Nougat Jul 19, 2018
    Artemus. , Jul 19, 2018 :
    From what I can see, OPPO uses different, skinnier icons than OnePlus, therefore can show more information.
  6. RinneganEye
    Cupcake Jul 19, 2018
    Vidi Fadilakbar likes this.
  7. deasom
    Honeycomb Jul 19, 2018
    deasom , Jul 19, 2018 :
    not gone, just the notch hides it until u pull down the menu. For me, it's a non-issue. knowing the network speed doesn't enhance my daily experience unless I'm having network issues.
  8. ngydat
    Lollipop Jul 19, 2018
    ngydat , Jul 19, 2018 :
    For the percentage, Settings -> Status bar-> Type of battery and choose percentage
  9. impop
    Cupcake Aug 2, 2018
    impop , Aug 2, 2018 :
    Please add this on Status bar instead of Battery Percentage...
  10. deasom
    Honeycomb Aug 2, 2018
    deasom , Aug 2, 2018 :
    why do all of u feel the need to SEE your network speed all the time. just wondering why this would be so important.
    ngydat likes this.
  11. FaleshC
    KitKat Aug 2, 2018
    FaleshC , Aug 2, 2018 :
    i don't get it either.
    Maybe because some of them wants to keep staring at network speed and battery percentage without actually using the phone.
  12. impop
    Cupcake Aug 4, 2018
    impop , Aug 4, 2018 :
    yes we're use to of it!
  13. Vuskasan
    Eclair Aug 11, 2018
    Vuskasan , Aug 11, 2018 :
    I also need that option too..
    not because i want to stare at it.. but i can see if my network down or not too by looking at the speed.
    dwhridoy and Ixigo1974 like this.
  14. FaleshC
    KitKat Aug 11, 2018
    FaleshC , Aug 11, 2018 :
    there are 2 small triagles near network bar, if you pay attention they represent if your data is working or not. i think thats sufficient for knowing if data is working or not. when on download or upload they change to solid or else remain opaque.
    GambitM and LegolasX like this.
  15. deasom
    Honeycomb Aug 11, 2018
    deasom , Aug 11, 2018 :
    U need it why?
    what useful information do u get by looking at your network speed all the time?
  16. nabbed
    nabbed , Aug 11, 2018 :
    I think we should round up all of these network speeders, line them up against a wall, and throttle their connections to 48 kbps.
    GambitM and KeepTransisting like this.
  17. KeepTransisting
    The Lab - OnePlus 7 Pro Reviewer Aug 11, 2018
    GambitM likes this.
  18. Vuskasan
    Eclair Aug 18, 2018
    Vuskasan , Aug 18, 2018 :
    Yup maybe some of you doesn't need it.
    But sometimes my connection just drop very bad... the triangle beside network bar still showing but the speed too low.
    If i see this, and see the connection only 0.xx to 9.x Bps then i will shut off the mobile data and reenable it again. Sometimes the connection back to normal.
    And it's okay when there's no feature for this, some of us maybe still comfortable by see that.
    Thank you anyway guys.
  19. Aks41179
    Jelly Bean Aug 18, 2018
  20. hotmomma
    Ice Cream Sandwich Aug 18, 2018
    hermit45 likes this.
