Display not showing on incoming calls
  1. ngydat
    Lollipop Oct 8, 2018
    ngydat , Oct 8, 2018 :
    I noticed that (that's why I added "(If you're on Pie)" in my previous post). Also, a lot of people seem to have the issue on Pie so I thought I proposed a solution here.
    yogbal likes this.
  2. G1538106568620
    Cupcake Oct 8, 2018
    G1538106568620 , Oct 8, 2018 :
    i also had the same issue on my op6 after installation of pie.
    There is no stable way out. i downgraded it to the stable version again.
  3. E1538317973518
    Cupcake Oct 8, 2018
    E1538317973518 , Oct 8, 2018 :
    if anybody else is having this problem on Android Pie, I madebit work with this solution. no need to reset it or wipe all data.
  4. Cr0k
    Cupcake Oct 15, 2018
    Cr0k , Oct 15, 2018 :
    thanks this worked
  5. Z1538819570351
    Cupcake Oct 16, 2018
  6. ngydat
    Lollipop Oct 16, 2018
    ngydat , Oct 16, 2018 :
    Could you post a screenshot of the last step ?
  7. Z1538819570351
  8. ngydat
    Ok I see nothing wrong there. Question :
    when someones calls you, what do you see ? Because I read people's threads and they talk about 2 differents issues with the incoming calls :
    1. The screen doesn't turn on at all. You only hear the ringtone
    2. The screen DOES turn on but people only see the "Back" and "Home" buttons and the notifications bar.
    So which one are you ?
  9. Z1538819570351
    Z1538819570351 , Oct 16, 2018 :
    2
  10. ngydat
    Then I understand why my solution doesn't solve your issue since it solves only the (1) problem. For your issue, I'm afraid I can't help you further.
  11. Z1538819570351
    I will wait for the next update then.
    thank you
  12. H1539697682156
  13. O1540713656192
    Cupcake Oct 28, 2018
    O1540713656192 , Oct 28, 2018 :
    Settings> apps and notifications>Phone app> Notifications> Incoming calls> Behavior> Make sound and pop on screen
  14. O1540713656192
    Please try this
  15. D1540807803599
    Cupcake Oct 29, 2018
    D1540807803599 , Oct 29, 2018 :
    it worked for me!
  16. B_Wrath
    Nougat Oct 29, 2018
    B_Wrath , Oct 29, 2018 :
    Read the solution given above and follow the instructions!
  17. Z1538819570351
    Cupcake Nov 5, 2018
  18. T1540017522720
    Cupcake Nov 8, 2018
    T1540017522720 , Nov 8, 2018 :
    its working gr8 bro
    #38
    Z1538819570351 likes this.
  19. DeepikAki
    Cupcake Nov 8, 2018
    DeepikAki , Nov 8, 2018 :
    I tried this, but my Notifications does not have anything. It just says Notifications are blocked. Attaching the screenshot.
    #39
  20. ngydat
    Lollipop Nov 8, 2018
    ngydat , Nov 8, 2018 :
    Probably because you disabled the notifications for the phone app
    #40
