Display problem
  1. Riddhesh Khatu
    Gingerbread Sep 3, 2018
    Riddhesh Khatu , Sep 3, 2018 :
    faced similar issue
    service center said the phone was waterlogged
    display replacement cost is 7500 including service charge
  2. dragon_unleashed
    dragon_unleashed , Sep 3, 2018 :
    same thing happened to me with oneplus 3t. It started from morning with 2 spots and by night it covered the whole screen and became pitch dark.
    The solution is screen replacement.
    Mine was under warranty, so oneplus replaced it for free.
  3. F_Arunaksha_Chakraborty_
    Cupcake Sep 3, 2018
  4. F_Arunaksha_Chakraborty_
    Cupcake Sep 3, 2018
  5. J1511795497417
    Cupcake Sep 3, 2018
    J1511795497417 , Sep 3, 2018 :
    If there is no physical damage it can be claimed under warranty.. Go to nearest one plus care and provide the phone for inspection.. If no physical damage is found and if under warranty period they will replace the screen for free... I have got it done for OP 3T
  6. SOMNATH310
    Cupcake Sep 3, 2018
  7. F_Arunaksha_Chakraborty_
    Cupcake Sep 3, 2018
  8. ghostofcain
    Marshmallow Sep 3, 2018
    ghostofcain , Sep 3, 2018 :
    Yes, it'll grow steadily until your device is unusable.
  9. F_Arunaksha_Chakraborty_
    Cupcake Sep 3, 2018
  10. Jogi5
    Ice Cream Sandwich Sep 3, 2018
    Jogi5 , Sep 3, 2018 :
    Phone dropped or you maybe have sit on it while it was in your back pocket
    ghostofcain likes this.
  11. vigneshmiller
    vigneshmiller , Sep 3, 2018 :
    Did you drop your phone?
    Bc I had the same problem it started from the left top corner and whole display gone bad
    Bc the screen is broken. But I don't remember dropping it or hitting against something. That happened to my Oneplus 3 and I changed my display with some 3rd party digitizer (it's an tft display not oled) it was cheap and stupid
    So I switched to Oneplus 6
    Idk how that happened to my phone.
    You can't fix it without replacing your digitizer. Replace only original oled displays if you love your phone. Don't waste money thinking the 3rd party screens are good ( I spoiled my Oneplus 3 with that cheap digitizer
  12. AmitExpectations
  13. G_Raza_Ali_GFmk
    Cupcake Sep 3, 2018
  14. ghostofcain
    Well at least you know the solution.
  15. G_Raza_Ali_GFmk
    Cupcake Sep 3, 2018
    G_Raza_Ali_GFmk , Sep 3, 2018 :
    Ya arranging money to get my display replacement [e]1f604[/e]
