Diztronic TPU Case & Audio Technica ATH-M20x
  1. Toon10
    Ice Cream Sandwich Feb 14, 2015
    Toon10 , Feb 14, 2015 :
    Can somebody confirm that the Audio Technica ATH-M20x plug fits into your OPO with a Diztronic TPU Case. The Audio Technica ATH-M20x could be to large and i want to be sure before i buy.
    I really want the ATH-M20x since it's one of the best headphones for under 50 bucks.
    thanks in advance
  2. gusuraman
    Community Veteran Feb 14, 2015
    gusuraman , Feb 14, 2015 :
    If I'm not wrong you can change the cable. So in case it doesn't fit you simply need to replace it with one with smaller plug.
  3. Toon10
    You can't change the cable with the m20x, that feature is only for the more expensive m40x and m50x.
    gusuraman likes this.
  4. gusuraman
    Right. Maybe @K.P. Smith can answer.
    Reus, K.P. Smith and Toon10 like this.
  5. K.P. Smith
    K.P. Smith , Feb 14, 2015 :
    Unfortunately I don't have the M20x. Although I'm willing to give it a go if someone want's to buy them for me :D
    Reus and gusuraman like this.
  6. K.P. Smith
    @Toon10 I'm sitting here looking at a diztronic case in my hand, and Google images of the M20x and my gut is saying no, it won't fit. It's not exact science but just doesn't look like it would fit.
    Reus, gusuraman and Toon10 like this.
  7. J.Pinkman
    Jelly Bean Feb 14, 2015
    J.Pinkman , Feb 14, 2015 :
    You have these mini cable extender cable thingies, i got one with my Philips citiscape headset. Maybe you could use that?
    Toon10 likes this.
  8. Toon10
    What's it exactly called? so i can search it on Amazon
  9. J.Pinkman
    Toon10 likes this.
  10. J.Pinkman
    Toon10 likes this.
  11. mpulford311
    Gingerbread Feb 14, 2015
    mpulford311 , Feb 14, 2015 :
    Unless you have a guitar center near you. I saw that they sell them, maybe pop in there and check in person. Just a suggestion
  12. Toon10
  13. Toon10
    you really should consider to review the M20x
  14. J.Pinkman
  15. Toon10
    I have just dicsoverd that the m30X might just fit in the OPO.
    The first one is the m20x, the second one is the m30X. The m30x has a screw thread, i own a cable with a screw thread and that one fits.
    [​IMG] [​IMG]
