OxygenOS DND mode badly implemented
  1. Dahnark
    Eclair Jun 9, 2018
    Dahnark , Jun 9, 2018 :
    With this title I want not to say that it doesn't work, really I didn't even try to check if it doesn't work, because the system had and have a DND mode better than the new one.
    The problem is this DND mode is hidden and you have to use a third app to open this system activity, in my case I am using this: https://play.google.com/store/apps/details?id=com.aiuspaktyn.nodisturb
    Then you get a screen where you have a few rules and you can create custom rules:
    [​IMG] [​IMG]
    Why implement a limited method instead of just create a shortcut to this system activity which it is working perfectly for weeks (I am using this method since I bought the phone).
  2. Dahnark
    Eclair Jun 9, 2018
  3. the_o2
    Marshmallow Jun 9, 2018
  4. Destabilizator
    Cupcake Jun 12, 2018
