Do I need Screen Protector for One Plus 2?
  1. atewathia
    Froyo Jul 29, 2015
    atewathia , Jul 29, 2015 :
    One Plus 2 has Corning Gorilla 4 screen, does it mean we don't need any Screen Guards/Protectors to save the screen from any unwanted scratches???
  2. basrone
    Jelly Bean Jul 29, 2015
  3. rphlfjrd
    Lollipop Jul 29, 2015
  4. Wrighty
    Wrighty , Jul 29, 2015 :
    Do I need an Atewathia Protector to screen his unwanted threads?
    Yes. Yes, I do.
    deejay01 likes this.
  5. Android
    Eclair Jul 29, 2015
    MCKenzy99 and guijan12 like this.
  6. Leon2512
    Gingerbread Jul 29, 2015
    Leon2512 , Jul 29, 2015 :
    I wouldnt bet on it.. In theory, the glass is not scrachable by knifes, keys, etc but somehow the glass will end up scratched. I'd advise a tempered glass screen protector as it provides great protection is is pretty much not noticable.
    sudarshankolar and oresmanhk like this.
  7. oresmanhk
    Eclair Jul 29, 2015
  8. accoolness
    accoolness , Jul 29, 2015 :
    No, I haven't used a screen protector for years and I have 0 scratches on my screen.
    Garywehrle likes this.
  9. EMLT
    Honeycomb Jul 29, 2015
    EMLT , Jul 29, 2015 :
    :D best comment :)
  10. PS00334332
  11. Chinda
    Chinda , Jul 29, 2015 :
    Correct but its safer to buy a better tempered glass screen protector ;)
    Ammar237 and rphlfjrd like this.
  12. atewathia
    Froyo Jul 29, 2015
    Exactly, I did use Google's Nexus 4 which comes with Corning Gorilla Glass 1 and it was supposed to be scratch proof, but over the time, I can see it has got some scratches... so... as most of the people say "Always Use Protection!!!"
    Does anyone has idea about if Corning Gorilla 4 will be any better than earlier versions???
  13. raghupro
    raghupro , Jul 29, 2015 :
    If you want your device screen to be impeccable then yes. If you want a non fussy experience in using your device then no.
    But anyways, irrespective of Corning gorilla glass 4/3/2/1 and how well you use your device the screen is somehow magically prone to at least some fine scratches that might not be easily visible.
  14. LevithanPC
  15. pscott37
    Ice Cream Sandwich Jul 29, 2015
    pscott37 , Jul 29, 2015 :
    I've not used screen protection for years and have been ok while carrying it in my pocket without a case. Hope I didn't just jinx myself. Is it fact that OPT comes with screen protector installed? I've read rumors to that effect.
  16. Bharathbijin
    Froyo Jul 29, 2015
    Bharathbijin , Jul 29, 2015 :
    Haha "always use protection",,,just use the screen guard ,,i had a oneplus one,,screen broke and had to pay around 12k Rupees to replace it( in India)..So just go with it..
  17. Radeon962
    KitKat Jul 29, 2015
    Radeon962 , Jul 29, 2015 :
    It will get scratched by sand that gets caught between the screen and another object. I don't believe GG4 has solved that issue.
  18. IndiaOPO
  19. pord
    Froyo Jul 29, 2015
    pord , Jul 29, 2015 :
    Depends on the user and what the user does with his/her phone
  20. Jmon885
    Jmon885 , Jul 29, 2015 :
    The gorilla glass is quite durable but it could still potentially get scratched. I would put a screen protector on it. You can usually find good screen protectors for less than $10 on Amazon. It's worth it, you don't want to scratch your new op2 by mistake.
