19
Do not disturb function via OnePlus 8 Pro
  1. Baronred
    Donut Mar 28, 2022
    Baronred , via OnePlus 8 Pro , Mar 28, 2022 :
    Since updating to android 12 the "do not disturb" function isn't really working. When I receive notifications (wahtapp or email) I still hear a sound or vibration. Any idea how I can turned it off?
  2. Tokolozi
    The Lab Reviewer - OPPO Find N Mar 28, 2022
    Tokolozi , Mar 28, 2022 :
    How did you configure it. In android 12 you have a few more options for DND such as allowing messages from starred contacts
  3. Baronred
    Donut Mar 28, 2022
    I just chosed the don't disturb option and didn't do anything else
  4. Tokolozi
    Long click DND and check the settings applied for them
  5. W1604738710715
    Donut Mar 30, 2022
    W1604738710715 , Mar 30, 2022 :
    Do Not Distrurb is broken in Android 12 update whatever you chose from the settings. I tested all settings, non of them blocked notification sounds, unfortunately....
  6. Neo83
    Cupcake Mar 31, 2022
    Neo83 , via OnePlus 9 Pro , Mar 31, 2022 :
    The only thing that I absolutely can't be without is still not working 🤦 OP9Pro is such a shitshow after 12. Guess it's back to 11 and stay there until I can sell it and buy a good phone, and sell this to someone who doesn't know 🤦
  7. S1648215895455
    Eclair Mar 31, 2022
  8. meekly
    Cupcake Apr 4, 2022
    meekly , via OnePlus 9 Pro , Apr 4, 2022 :
    Same issue here. DND isn't working at all, all notofications are sent with sound from all the apps. Even the "enable DND" is throwing the notification sound, which is annoying.
  9. Rollmop
    Cupcake Apr 6, 2022
    Rollmop , via OnePlus 9 T-Mobile , Apr 6, 2022 :
    DND is not allowing silencing anything other than media, volume can be lowered but not silenced for everything else unless you set individual notifications to silent. The override DND function is not working, still overrides even when off.
    4shaneob likes this.
  10. L1617389018334
    Cupcake Apr 12, 2022
  11. Mortenbl
    Cupcake Apr 24, 2022
    EgoSumLuxMundi likes this.
  12. Elderwand19
    Cupcake Apr 25, 2022
  13. Blunijo
    Cupcake Apr 26, 2022
  14. #14
  15. #15
  16. P1600713079620
    Cupcake May 2, 2022
    P1600713079620 , May 2, 2022 :
    Absolutely puts me off even considering another OnePlus phone after my 8T updated to 12 now refuses to mute notifications when on DND. It's a basic common sense requirement that when you select DND you don't want to be disturbed. I'm going to have to test it with the slider switch and see if putting it on vibrate allows me to sleep through. I can't accept being woken up by notification sounds several times through the night, it's ridiculous !! Worked fine before the update.
    Maybe I'll try changing the notification tone to the quietest one and see if that helps, but that would mean changing it back every morning or risk missing possible important notifications. I've spent the last 3 days discovering new "BROKEN" things within the update to 12. It's unacceptable to be putting out such a mess of an update IMO.
  17. LeGlitterChiot , via OnePlus 8 Pro , May 3, 2022 :
    So I followed the fix for another bug I was encountering (no Gmail notifications) which was to turn off the phone completely for over three minutes and then power it on again, and that _seems_ to have fixed this too?
    EDIT: Okay looks like I spoke too soon... I also hate that it's an only on/off feature now, you can't set it for a certain amount of time when you turn it on like you used to be able to
  18. Hanger999
    Cupcake May 3, 2022
    Hanger999 , via OnePlus 8 Pro , May 3, 2022 :
    Since the big update it seems that the facility to 'allow' alarms to sound despite do not disturb being selected. Why has this been changed?
    Surely the biggest use of do not disturb is when sleeping but you still need the alarm clock to make a noise to wake you up.
    Yet another unnecessary change.
    Is there any way of allowing the alarm clock to sound whilst having everything else muted?
  19. alberto_chia
    Cupcake May 18, 2022
    Andrey_vb likes this.
  20. C1595267410530
    Donut May 23, 2022
    C1595267410530 , via OnePlus Nord , May 23, 2022 :
    I am One plus nord user. Updated to Android 12 and now surprisingly do not disturb does not work. Will one plus be releasing another update to fix it? I am really pissed off . When I applied do not disturb I do not want what's app or other social chats notifications not to come when I am watching movie or doing something important on phone however notification is coming everytime. I tried blocking everything in Do not distrub but nothing is working.
