299
[DO NOT USE] [GUI]OnePlus One Toolkit by manudroid19
Thread Status:
Not open for further replies.
  1. manudroid19
    Honeycomb Sep 1, 2014
    nokistein likes this.
  2. manudroid19
    manudroid19 , Sep 1, 2014 :
    ouais... c'est completement bizarre... et plus avec chrome ou autres antivirus
  3. DRCH
    Marshmallow Sep 1, 2014
    DRCH , Sep 1, 2014 :
    @manudroid19
    Pretty good support for your tool ;)
    Havent seen simwthing like that around here :)
    Good to See you keep your tool updated !
    manudroid19 likes this.
  4. manudroid19
    install or boot twrp, do a nadroid backup, the root and then efs backup
  5. manudroid19
  6. manudroid19
    after answering every post, I would like to say:
    I NEED AN INVITE!!
    If someone can give me one, please do it soon and you will get this updated!!
    Steffert, nokistein and Cristianvila like this.
  7. Cristianvila
    Ice Cream Sandwich Sep 1, 2014
    Cristianvila , Sep 1, 2014 :
    si tuviera te daba una o las que sea te las mereces! como ves en mi firma ya e repartido 9 en este foro :D
  8. rsgeiger
    Donut Sep 1, 2014
  9. hawkinspace
    Donut Sep 1, 2014
    hawkinspace , Sep 1, 2014 :
    Thanks for taking the time to reply, no the screen does not get brighter.
  10. gatm
    Donut Sep 1, 2014
    gatm , Sep 1, 2014 :
    I've got an issue.
    The textboxes don't show correctly:
  11. stang77
    Froyo Sep 1, 2014
    stang77 , Sep 1, 2014 :
    Hi
    I just want to root my One, that's all, nothing more. Can you confirm that this is the right procedure :
    1. download .zip
    2. run .exe
    3. "download and install drivers"
    4. enable USB debugging on mobile
    5. plug mobile on PC via USB
    6. "enter fastboot"
    7. "unlock bootloader"
    8. "root"
    Is it correct ? Many thanks
    muhdiboy, manudroid19 and evilriq like this.
  12. Maica
    Jelly Bean Sep 2, 2014
    Maica , Sep 2, 2014 :
    Hi, first thanks for your toolkit @manudroid19, and forgive my bad English because I've had to use traslate.
    I wanted to ask how to enter bootloader mode from the computer is turned off mobile ?. recognized as the connecting device and load, but I can not send adb commands.
    It is curious, and to know what to do if they can not turn on or use the buttons.
    for exam. the jiayus have a computer application with which you can put a rom without having the mobile battery
    The Samsung with usb jig also come, the One does not, I've tried.
    I tried to do it from your application, but also gives me error, I succeeded only once taking off reboot to advanced mode.
    It is problem of my pc or is not contemplated that possibility?
  13. manudroid19
    Honeycomb Sep 3, 2014
    manudroid19 , Sep 3, 2014 :
    are you on 33R??
    have you unlocked??
    hawkinspace likes this.
  14. manudroid19
    wow! things don't show correctly because the toolkit wasn't made for that UI.
    I think you can fix text boxes resizing window to the right...
  15. manudroid19
    yes... most important is not forget to unlock bootloader..
  16. manudroid19
    dimelo en español mejor jajajajajj
    Maica likes this.
  17. shcxatter2
    Ice Cream Sandwich Sep 3, 2014
    shcxatter2 , Sep 3, 2014 :
    hi manudroid19, I want to ask you:
    if i have rooted the OPO on 25R and after the update to 33R lost root, is the bootloader still unlocked :)
  18. hawkinspace
    Donut Sep 3, 2014
    hawkinspace , Sep 3, 2014 :
    Hi, yes i am on 33r, and i am not unlocked no, a command box pops up but nothing happens it stays in fastboot with a dim screen when i try.
  19. manudroid19
    yes it is
    TheJames and hawkinspace like this.
  20. lestergoh
